    Feb 12 2015
    Ohio
    Radiators fans only work when overheating?
    02 b6 a4 1.8t amb engine, Overheated on the highway one day, got the car home...replaced the water pump(not knowing that it was already the aftermarket metal impeller...big waste of time) and then the thermostat. This fixed my overheating problem. But i also realized that the fans arent coming on with the a/c, or even when the car is at operating temp. They only kick on when the engine starts to overheat at idle, and then they cool it back down.
    The fans are obviously getting power...so could this be my fcm?
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    It could be the coolant temp sensor
    Feb 12 2015
    Ohio
    The rear CTS was replaced about 2 months ago
    Jul 20 2015
    Mesa, AZ 85207
    What about the other one? Not sure if that'd cause it but it's a cheap trial
    Dec 22 2015
    Chico, CA U.S.A.
    [IMG][/IMG]
    Radiator Fan Control Module (300W)
    Sent from my SM-N910V using Tapatalk
