    Feb 19 2015
    United States
    HELP!! Need Replacement Fan Connector PIC Included
    I have a 2014 S4 and am in need of one of the electric fan connector on the engine harness. One of mine were damaged and I don't want to buy an engine harness to get one connector.
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Did you already try searching for it on www.genuineaudiparts.com?
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    There should be an Audi part number (like "XXX YYY ZZZ B") molded into the connector body. You should be able to buy that from an Audi dealer. Find the release tab on the old connector, and pull the wires (with pins) out of the old connector body, and install into the new connector body.
    Where is the damage?...kinda looks usable to me...maybe just clean it up with some Brake-Cleen spray (no residue)....
    Feb 19 2015
    United States
    Thanks for the web link. I called my Audi dealer and they said the plug wasn't serviced and I needed the entire wiring harness for $1,600. I put the number in the website and it pulled up a listing for $8 but there is no picture. For $8 I'm gonna take a shot at it though.
    The picture is of the good one, the other one is crushed all that is left are the wires.
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Would it be an issue to just strip and crimp the wires together and not use connectors at all?
