Originally Posted by
Luxus Panzer
mounts for sure. Have a look at your snub mount.
Looks to be the easiest one to replace too. I spoke to a local shop and they mentioned if the snub mount is bad for long enough, it can put more strain on the hydraulic motor mounts and result in them going out also. Since I don't have much history on the car, and since the OEM snub mount looks like a plastic/foam and seems pretty soft, I'll assume it's been gone for some time now.
Charles.waite
^^ Agreed on the mounts. Check the snub mount first. I would just buy an aftermarket poly snub mount and replace it regardless, the stock one is mushy and adds a lot of vagueness to the shifting.
I'll take a peak at the snub myself and see what condition it's in. I suppose I can also do a visual on the left/right motor mounts and see if they have leaked out or not. That should be a pretty clear indicator that they are toast.
Thanks for the replies guys.
PS: At 150k miles, do you think the motor mounts should be replaced also? I really don't know how long these should last with normal use. My gut tells me to do the snub as well as both left/right motor mounts. Any advice on this is appreciated.
