Results 1 to 9 of 9
Thread: Intake Question
    Sep 01 2014
    Houston Texas
    Intake Question
    I get it... the stock air box is good enough to hold up to 300hp (Or So). So I'll take your advice and not buy an intake... but what about the turbo inlet pipe? ANY benefits or improvements joining one with the stock air box? I only ask because APR currently has their TIP for sale for $99.99 rather then the normal $199.99 and I'm itching to buy one. At the same time... I'd like to gain a benefit. Let's be honest... I love the semi truck hiss and blow off sound from a aftermarket diverter valve also. My girl gifted me a K&N drop in filter (I know... I know) but I needed a filter anyway so I have that for now. Last question: Does any of the "Holes" on the TIP have anything to do with the SAI? I ask because eventually I want to delete it. Thanks in advance!!!
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Changing to an aftermarket turbo inlet pipe will not provide any power gains. They are good for the fact that the stock rubber ones seem to have a tendency to crack. That is the only real benefit that I know of. The silicone ones are very nice though for this purpose. And no, none of the holes on the intake tube have anything to do with SAI.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Some also say that an aftermarket TIP won't collapse under high vacuum (like WOT) as the stock one might. I can't verify that the stock TIP is prone to collapsing though.
    SAI connects to the air box lid, and has no attachments to the TIP (at least on the B5).
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Sep 01 2014
    Houston Texas
    Thanks. I have another small question. APRR1 or Forge... or is it just Preference?
    Jan 30 2012
    Brunswick, Ohio
    I have a forge and it's held up really well over the years
    Sep 01 2014
    Houston Texas
    Yeah... Forge is a bit cheaper too. Any advice on the best drop in? Is AFE the best for our cars or AEM... Once again... thanks in advance.
    Veteran Member Three Rings c0r3y.af's Avatar
    Apr 04 2012
    Warwick, RI
    Drop-in filters are all going to be roughly the same - ignore whatever HP gains they advertise. I'd just go with whatever is cheapest. You can also look into the "swiss cheese" mod if you'd like a little more airflow and sound. It basically involves strategically cutting holes into your airbox to improve flow.
    Forge and APR are both great DVs. I personally had a Forge Splitter for a long time and loved it.
    Sep 01 2014
    Houston Texas
    Yeah I'm not concerned about any horse power gain. I know I'm not gaining anything significant in that area as I'm bone stock other then a drop in K&N which even I don't consider a mod. I'm currently looking into the Swiss cheese mod just to entertain myself while I would on this groceary list of maintenance.
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    A TIP might increase hp a bit, and should definitely improve responsiveness of throttle/boost. Swiss cheesing the airbox will improve turbo noise, response, and DV noise.
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
