Results 1 to 3 of 3
    Sep 21 2014
    San Diego
    Airbag light ?? How to remove
    I changed my seats and forgot to plug one of the seats in b4 I reconnected the battery and the airbag light came on any idea how o remove it I have a diagnostics tool but it isn't that high tech
    Apr 15 2014
    Ottawa/Gatineau Canada
    Vag-Com
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 26 2005
    Is the air bag wire connected now? If it is, then you will have to clear the fault codes in the air bag controller to clear the warning light. Use VCDS or am indy Audi shop, or a lock smith or the dealer to clear the fault codes stored in the air bag controller
    Also, the air bags will not deploy in an accident if the air bag light is ON.
    Vorsprung durch Technik
