Results 1 to 10 of 10
    Jun 18 2013
    United States
    Vag-com Issue - DRLs failure when headlights are turned on:(
    I recently updated the Vag-com coding to reduce the DRL brightness from 28% back down to the factory setting of 9%. The code took fine, but if I start the car with the headlights off the DRL functions normally and is back to 9% based on the brightness. Unfortunately, when I turn on the headlights I immediately get the following error:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 242
    Mileage: 31362 km
    Time Indication: 0
    Date: 2015.12.08
    Time: 19:43:18
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 242
    Mileage: 31362 km
    Time Indication: 0
    Date: 2015.12.08
    Time: 19:43:18
    I compared my log files and noticed one change in the long code, see below:
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Long code from earlier scans:
    26000011803CAFF2390040C300003D0D0F9CD308A20902210000080040000702000400 30000000
    Recent long coding…
    26000011803CAFF2390140C300003D0D0F9CD308A20902210000080040000702000400 30000000
    Can I update the long coding and change the "1" to "0" or will it create additional problems? I don't want to brick the car!
    Any help would be greatly appreciated!
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    You could always go back to the 1 if it's not the fix. Are you seeing any lights, or are they both not working when you turn the headlights on? I did this years ago and I set the brightness to low and only one light worked. I just added two % to the value and it worked fine after that.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jun 18 2013
    United States
    Quote Originally Posted by TexasDfwS4 View Post
    Thanks for your suggestions. I've tried returning the brightness to 28% and the same thing happens, the DRL function fine until you turn on the headlights. Then they turn off of both sides.
    Sounds like I should be able to change that one bit and see if the problem is gone. Since the DRL functions when the headlights are off, this points me in the direction of a coding issue.
    Junior Member One Ring
    Aug 16 2018
    UK
    Hi all
    I have the same issue on a A7 2013, does any know how to fix this? Tried dealer but the could not fix either - I know it’s a coding issue as the lights work on auto, but soon as you switch full beams they turn of
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Maybe Ross Tech could help? They may at least know the factory coding value to reset it.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    There is a threshold at which the LED lights won't activate. On my car I believe it is about 18%. Anything less and the LED's won't come on and you get an error message. If you don't have LED's I don't think this is a problem. At least it wasn't when my last Audi had the xenon lights. I would just adjust your brightness to the lowest number possible.
    Sep 10 2012
    DFW
    Add so percentage and it should come back. Mine was 8% and it would work.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Aug 16 2018
    UK
    Thanks for the replies guys, they guy with pc and software is trying activate the leads on full beams but he gets an “error 31 code”
    Aug 16 2018
    UK
    Tried to add with software but get an “error31” this is really beginning to piss me off....
    Aug 16 2018
    UK
    sorted now, just put in 28 % and they worked again, just some advise going forward from you experts:
    (1) When switched to auto, the DRL are bright, i assume at 100%
    (2) when i manually switch to day light, they dim down, i assume to 28%
    (3) when on full beams they stayed dim at 28%
    so surely when they are in manual day light the drl should be at 100% brightness, is this correct?
