Results 1 to 14 of 14
Thread: P0299
    Jun 23 2015
    1991 Mustang 5.0 Vert - 315 whp 360 tq
    P0299
    Recently, I have scanned the vehicle and cleared codes after I had a low oil pressure problem which the underlying cause was the PCV valve. I had a TON of blow-by issues. Now that that is all fixed, I am getting a low turbo boost issue with the P0299. Any ideas on where to start?
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    DV then waste-gate actuator rod. Make sure your DV is still in working order. Next check if there is any play in your waste-gate actuator rod. If you're under warranty or 70,000 miles, call AoA to see if you qualify for the turbo TSB.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Jun 23 2015
    Quote Originally Posted by bakedziti View Post
    Unfortunately I am at 77000 miles and it started just recently. So I don't think that I'll qualify for the TSB. What necessarily is the DV? I am a technician but this is my first FI car. So I am new to the turbo world.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by STA4 View Post
    +2, this has been discussed at length in here, also search here: http://wiki.ross-tech.com/wiki/index...3/P0299/000665
    Stage 1 more than you RS3
    Jun 23 2015
    Quote Originally Posted by o1turbo30v View Post
    Much appreciated. The top link ouldnt work no matter how many times I clicked on it. I will look into it this evening.
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    Its your Turbo! I been through this journey. Just replace it. They have a issue with a turbos on certin VIN's and if your over 75,000 miles they can't do anything for you.
    Oct 23 2014
    _
    Quote Originally Posted by ccoaston View Post
    Can't and won't are two different things. You can always ask, as it won't hurt, but what they will do is a different story. I would at least let AoA check the VIN before I run out and grab a turbo myself. That said, replacing your turbo isn't that hard; provided you have all the tools.
    OP - your DV is your diverter valve. If you can get the car on ramps or jack stands, you can get access to the DV from underneath and you can check to see if it needs to be replaced.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jun 23 2015
    I have all the necessary tools to do anything I need to, and a full shop. Really trying to stay away from the turbo because I'm not trying to spend that much money.
    Oct 23 2014
    _
    Quote Originally Posted by MacAnthony View Post
    You can get a turbo for less that I think you're expecting. I ended up replacing mine with a used K03 from an A5 with 20,000 miles on it. The turbo was just under $500, and then I grabbed the ECS install kit for ~$75; after that it's just your time and effort.
    I would check your wastegate rod for play first however, because that seems to be the reason that many of us have received the P0299 code. I used the thread below to help diagnose my issue, although I didn't use the below thread for the DIY they explain. They have a link in there to to a ticking sound that can be attributed to the wastegate while coasting. I am not sure if you experience this, but mine was noticeable before I ever got an MIL.
    http://www.audizine.com/forum/showth...lapper-(P0299)
    For my DV comments, you can use the below thread from the B7 forums to get an idea of what to look for. It's not exactly the same, but its pretty close. First you'll want to determine which DV you have, and if it needs to be replaced. I recently replaced mine with a GFB DV+, for $140 just for piece of mind.
    http://www.audizine.com/forum/showth...l-Installation
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jun 23 2015
    I do get a buzzing/ticking sound while coasting. Funny thing, the code disappeared once I got in the vehicle this morning. No CEL illuminated, which is weird because of VW... I'll look into it, I ended up not having the time I thought I was going to have yesterday so possibly today/tomorrow. Thanks for the help Ziti!
    Jun 26 2009
    Bremerton WA
    The code will still be stored in the ECU. The light will go off after the car meets the range of boost requested vs supplied. There has to be about a 5 or 6 psi loss before the light comes on. So usually you are losing quite a bit of torque in low RPM's and don't even know because the boost numbers aren't that high.
    I wrote the DIY a few years and about 30K miles or more ago and my wastegate is still tight.
    VMR 710's, APR software, Eurocode HFC
    Oct 23 2014
    _
    The MIL will come and go, at least mine did. I was in the middle of some family stuff at the time, and had my car in for Stage II of the oil consumption fix, so I waited until I got a definite no from Audi for a warranty replacement. Finally I just got sick of seeing the light, and the lack of power, so I changed the turbo.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    You should ask since the code may have been there w/ the other issues you had. 2K over the extended warranty should be honored it being a known issue. You could be aggressive and just call AoA and have them work with the dealer.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
