Results 1 to 31 of 31
    Registered User Four Rings
    Oct 27 2007
    NA
    True Philips Deep Golden Yellow X-treme 2700K LED fogs available from HIDCONCEPT.COM
    PHILIPS 2700K X-treme Ultinon LED Golden Yellow for H8/H11/H16
    For those who have been waiting for true deep golden yellow for fogs, you might want to check this out.
    It is currently on super hot sale at $139.99 (reg. $179.99).
    You can also take an advantage of our holidays sale discount; 10% OFF.
    Use code : HAPPY10 to save additional 10% with FREE Standard shipping option for US and Canada.
    The promo runs until 12/25.
    Let us know if you have any questions.
    1-888-579-5917 or email at [email protected] .
    Senior Member Two Rings Demringstho864's Avatar
    Sep 26 2015
    Syracuse NY
    What makes these better then say a yellow bulb, or a 3000K hid kit that can be had for a quarter of the price ???
    2009 A4 2.0T Quattro Premium Plus
    Static dropped on 20s, lots of bolt ons, and some appearance stuff
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by Demringstho864 View Post
    youre spending more for the brand. i got 4 H11 6000k fog bulbs on ebay for $5 bucks lol. you cant tell the difference between piaas and these
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Oct 27 2007
    NA
    Actually, there are quite many differences.
    - HID kit on fogs is not really recommended way since it can blind on-coming traffic.
    - glare issue (when using standard d2s-based HID kit). These LED's are designed to have correct lighting beam pattern facing downwards to shine toe ground only.
    - Most 3000K HID kits do not give true deep golden yellow like these LED's. (PHILIPS LED's do give the most yellow color IMO. If you are fan of 3000K HID kit, we have them as well. :D)
    - Brand name. Philips is known for its quality.
    - BTW, these LEDs do give 2200lm (stock halogen is around 1200lm +/-, HID generally gives 3200 lm +/-)
    Oct 27 2007
    NA
    Quote Originally Posted by JeriQo View Post
    Glad that you found bargain on those LED's.
    You are not comparing these Philips to $5 LED though, right? lol
    Jul 08 2015
    Quote Originally Posted by mike@hidconcept View Post
    not the phillips. to the piaas
    Aug 06 2012
    Parker, CO
    A couple of questions
    1: Do these already have resistors so a light warning isn't thrown?
    2: I have the "cornering light" function activated thru VAGCom..... will these bulbs dim like the incandescent bulbs do right now?
    That is all.
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    this answered my question i posted in the S4 section...thanks Mike...ill stick with my HIDs since i really like blinding oncoming traffic
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Oct 27 2007
    NA
    They should not give error message as we already tested on B8 A4, B8.5 A5, Porsche Cayenne, and Porsche Macan.
    No fault was found.
    Sorry but I'm not sure about cornering lights though...
    It should dim down but at faster pace.
    Established Member Two Rings ekyp's Avatar
    Aug 24 2012
    Vancouver, BC
    Quote Originally Posted by treginginco View Post
    That is all.
    I have the regular white LED Philips X-treme Ultinon for my fog light.
    True plug and play with no error. I have the 'cornering light' enabled as well and the led would also dim in and out (similar to the OEM incandescent)
    2017 Audi A4 S-Line | Mythos Black, 2019 Audi S4 | Mythos Black, 2021 Audi SQ5 Sportback | Mythos Black
    Oct 27 2007
    NA
    Quote Originally Posted by ekyp View Post
    Awesome!
    Aug 06 2012
    Parker, CO
    Great ---- Thank you!
    Oct 27 2007
    NA
    Oct 27 2007
    NA
    Sorry for those who saw 'out of stock' message.
    Please don't worry as we just received new shipment in.
    Jan 03 2012
    Wilmington NC
    Mike...why dont they make HIDs that are lower than 3k? i want like a 2200K DEEP yellow fog
    2019 S4 Build
    IG: @steves_s4
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    I have a very similar set of Philips LED fog lights and they do work with the cornering lights feature.
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Oct 27 2007
    NA
    Quote Originally Posted by SleeperCar View Post
    Not sure why but these 2700K LED's give enough deep yellow color.
    I think that these are yellower than any 3000K HID kits you can find IMO.
    Jan 03 2012
    Wilmington NC
    yea i already have the 3000k Blesk installed. thanks for the info
    2019 S4 Build
    IG: @steves_s4
    Aug 15 2014
    Bump for TheFifthDagree
    For Sale: Mini Part Out
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    Quote Originally Posted by Shimmy View Post
    LOL
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Established Member Two Rings 99r6's Avatar
    Dec 03 2015
    Wichita
    Anyone have a picture of these installed?
    Oct 27 2007
    NA
    Happy Saturday.
    Just wanted to let you know, if you order $200 or more, you can save 20%. Use coupon code; HAPPY20.
    Established Member Two Rings macscac's Avatar
    Mar 20 2014
    peoria, az
    i would also like to see photos of them in action..
    Aug 15 2014
    ^ i'm running some cheap yellow bulbs at the moment. Would love to see this in a vid or pic.
    Dec 12 2014
    Bolingbrook/Illinois
    Will these help to improve vision during nighttime rainy driving? OEM fogs do a little since they are more yellow than the HID headlights but I would imagine a more yellow would be more beneficial? Would an LED bulb give the same effect as a standard bulb?
    2012 A4 P+ quattro S-line appearance
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by COLD13 View Post
    The OEM fogs do little because a 55w halogen bulb doesn't produce much more than a third of the output of an OEM HID bulb. On top of that, it's in a much less efficient housing. So they're hardly noticeable when the HIDs are already on. If you want something that produces noticeable light, you need something with much more lumen output than a 55w halogen bulb. As far as whether or not there are any benefits to yellow, there's a good article about that here.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Dec 12 2014
    Quote Originally Posted by dscline View Post
    Thanks for the info, that is actually a pretty interesting read. This is my first car with HIDs and they are great until you get on black pavement in rain. Lighter color pavement in rain seems fine but the blackest pavement makes the light bounce away as if the road is a mirror leaving me questioning if my headlights are even on. I've have never experienced this before I drove with HIDs. Maybe it has to do with getting older as well, haha.
    Oct 27 2007
    NA
    Yes, yellow fogs are not for the look only but to increase visibility on foggy and wet road surface. It actually does help a lot.
    Oct 27 2007
    NA
    Sale ends tomorrow.
    Happy Holidays!
    Jul 08 2015
    how does the cornering fog light work?
    does it turn where you turn? not that i think its possible but i have a p+ and that setting can be enabled on the carista app
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Yes, if your headlights are on, the fog light on one side will turn on when you either use the turn signal, or turn the wheel in that direction. But it doesn't just turn on/off like they do when you use the fog light switch, they fade in/out, which is a concern for some lighting types, particularly HIDs which aren't intended to be dimmed.
    '11 S-Line A4 Avant
