Originally Posted by
jaychen
if your car worked before you pulled it apart, im 99% sure it's hardware related.
check to see if you have fuel physically spraying, if you do not, something is a miss (obviously).
methodically work backwards from the rail.
have you bench tested the fuel pump? I know you said you have pressure, but just for the sake of it?
cant really screw the feed/return up, one is threaded, one is not.
Jaychen-you were exactly right! Determined that the injectors were not spraying fuel. Assumed it was an electrical problem somewhere down the line-wrong assumption. It turns out it was the fuel injectors themselves-all six of them. I am going stage 3 and had ourchase some green giants from a member on the forum quite some time ago. They sat for a while at my location and who knows how long he had them sitting around before I bought them. Every single one was plugged totally. Put my old injectors back in and the car started immediately and runs fine. Can't thank everyone enough for all thye suggestions. I have an Awe stage 3 ecu. New Ko4's just installed along with Rs4 clutch, catless downpipes and Miltek exhaust. Question I have now is, because of the Awe stage 3 tune, is it best to install green giants rather than another type injector?
Again- really apprecaite the help-been tearing my hair out thinking I did something wrong during the clutch/flywheel install or engine re-install.
