Results 1 to 16 of 16
    Jun 12 2015
    CA
    Can I go APR Stage 1 to GIAC Stage 2?
    The APR dealer in town refuses to install the JHM pulley while installing the APR Stage 2 pulley. So now I have a problem because i don't want to pay to have the car cracked open twice, and the belt removed twice. Has anyone gone from APR Stage 1 software to GIAC Stage 2 software/pulley? Would i basically have GIAC software after the Stage 2 install?
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by colby7 View Post
    You want to run both the JHM and APR pulley? Isn't that a bad idea since the JHM pulley is suppose to do, @ the crank, to what the APR pulley already does at the supercharger? That would likely push the supercharger beyond it's limits of efficiency and cause long term problems
    **note there are two pulley's the light weight and the over sized, which one are you trying to install? It looks like from the description both are terrible to use if you are using the APR pulley from their description, it's one or the other...
    https://jhmotorsports.com/shop/catal...a8-p-3307.html
    vs
    https://jhmotorsports.com/shop/catal...a8-p-3392.html
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Yeah + GIAC is having their holiday sale. But like Rudy said get the LWCP, not overdrive pulley.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by q5 dave View Post
    well just to be clear, if you go Stage II, whether GIAC or APR (or other brand) for the tune
    hardware wise you can :
    replace the supercharger pulley
    OR / and = bad
    replace the crank pulley
    Our Overdrive Pulley replaces your OEM crank pulley, drops the overall weight of your 3.0T's rotating assembly, and upgrades you to stage 2 pulley ratios - all without changing the pulley on your supercharger!
    The APR dealer was in the right, and said the right thing that they won't install both pulley's
    Past
    Jun 12 2015
    CA
    I think you're getting hung up on a detail in the question. In hindsight i shouldn't have even mentioned the pulley or the shop. I'm not interested in an opinion on what's safe. I'm also not interested in debating whether the shop should do the work. I'm just interested in knowing what happens when switching from APR Stage 1 to GIAC Stage 2. Has anyone done it? Do i have to pay for GIAC Stages 1 & 2, or just pay for Stage 2?
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    The thing is only cost. GIAC won't "stack" with the APR tune. If you go GIAC Stage 2, it will be GIAC only, the APR software will be overwritten. As to the cost, I don't believe GIAC has a promo discount for coming from APR Stage 1, so you're looking at full price to go Stage 2 unless I missed something.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    Maybe wait for the new fluidampr bottom pulley for stg2, changing the top will be in the past..giac stg 2 extreme? who knows..
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    You can switch without issue. It's just wasting extra money. You've already paid for an APR software license and any performance advantage with GIAC over APR is negligible. Doesn't make sense, IMO. Your last question is a bit confusing. You'd pay for stage 2, which is for the software and pulley kit.
    Find another shop who is willing to install the pulley. Sounds like your shop is being stubborn for no reason.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 20 2014
    Pittsburgh, PA
    Quote Originally Posted by LINDW4LL View Post
    I think this is a good idea. Just have another shop install both pulleys, then go back and have the first shop just flash the ECU.
    Previous:
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by RudyH View Post
    OR / and = bad
    I think you are confused. I said stage 2 with the light weight crank pulley is fine, but should avoid the lightweight overdrive pulley.
    If you have concerns talk to @AudiStealth. He is stage2 w/ LWCP. No issues.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Yeah Colby you would hate it if your car made that much additional power using both the od pulley and the smaller s/c pulley. AVOID!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    FWIW, for the most part, without a software change, boost levels will be higher than our targeted values, and as such, the ECU will open the bypass valve and bypass boost.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Aug 23 2008
    Auburn, AL
    GIAC should be able to write over top of our software, just as if it were stock. Alternatively, you can always flash the ECU back to stock at an APR dealer before flashing GIAC software if that's their preference.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Why do you want to switch from Apr?
    If its for customer service then maybe? Or closer to gaic dealer.
    But for performance aspect there pretty much the same..I am very happy with my stage2t,I'm also running duel pulley setup (but not reaping the benefits yet) just hoping Apr will release the tune for that soon! Then it might be a different game.
    Aug 15 2015
    2 feet
    Niagara canada
    Also I'm sure there's someone on this forum that would swap out the pulley for you much cheaper than the shop would charge you..If I were closer I'd help you out!
    Sep 13 2015
    North
    It's only a couple hours even if it's done twice, so I think you'd be cheaper upgrading then starting from scratch.
