Results 1 to 23 of 23
    Established Member Two Rings realax's Avatar
    Jul 10 2015
    los angeles
    19x9.5 et37 too aggressive??
    Hey guys,
    So I'm thinking of throwing on a new set of wheels on the Avant, and wanted to get your thoughts.
    19x9.5 et37 all around are the specs, planning on running 2353519 so it'll have a slight stretch.
    Do you think i'll have inner clearance issues? has anyone run this setup before??
    any input, and pics would be appreciated!!
    Best,
    Senior Member Two Rings Yogie's Avatar
    Jul 30 2013
    05' WK Jeep 5.7l Hemi
    So Cal
    Could be wrong, but I'm pretty sure there is a thread here somewhere devoted to wheels/suspension set ups. Wheel size, spacers, suspension, rubbing issues, and clearance. Might find what you need in there.
    '2008 Brilliant Black A4 Avant S-line/Ti 6Speed Quattro'
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    I run 19x9.5 et40 in the rear but with a bigger tire. 245/35
    et 37 with a 235 will shouldn't be an issue, at least on the rear. Set the camber close to max though
    Jul 10 2015
    los angeles
    thanks for the heads up..i think your referring to the "stance" thread.
    and you're right i found some good info!
    Jul 10 2015
    los angeles
    Quote Originally Posted by AJacksA4 View Post
    whatr you running on the front?
    Nov 26 2011
    Quote Originally Posted by realax View Post
    19x8.5 et32 with 235/35
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    I ran 18x9.5 et40 all around, although its super tight on clearance on the inside of the wheels. I would bet that 3 mm should help out on the inside, although with a 19 your ability to run a 235 is gonna be dependent on how low you wanna go. Check out this thread for some good info:
    http://www.audizine.com/forum/showth...ghlight=stance
    Tony is running pretty similar specs, so might be worth checking out:
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    you'll be fine I ran 19x9.5 et 35 with 235/35/19 tires with no problems I was somewhat low too.
    Jul 10 2015
    los angeles
    Quote Originally Posted by derrek View Post
    Thank you for the input! Exactly what i was looking for!
    Hopefully my car looks half as good as yours loll
    Jul 10 2015
    los angeles
    also..did you have to pull or roll your fenders?
    Nov 13 2011
    b7 s4 avant
    My new wheels are 19"x9.5 et30 and I think I'm going to go ahead and run 235's
    I drive a truck now.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    235 on 9.5 is still a stretch, though. IIRC, 235 on an 8.5" is a stretch, so 9.5 definitely will be.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Nov 13 2011
    b7 s4 avant
    Quote Originally Posted by JDillon15 View Post
    I ran 225 on an 8.5 which was a mild stretch in my opinion, so I imagine a 235 on a 9.5 will be similar. I can't go for meaty unfortunately lol
    Dec 14 2008
    Bay Area
    235 on a 9.5 isn't bad at all.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Jul 23 2010
    arizona
    235 hankooks on a 9.5
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    I run 19x9.5" et35 all around with 225/35-19 Hankook V12 K120's with no issues. I'm about as low as you can go running 19's static @ 23 5/8" FTG front and 23 7/8" FTG rear. My build thread that Pat linked (also in my sig) has more info and photos.
    225's stretched on a 9.5" isn't bad...
    AG M580's in da house by Tony Mollert, on Flickr
    Lows
    Untitled by Tony Mollert, on Flickr
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
    Jun 30 2015
    Ohio
    i ran 9.5 +20 in rears and 9.5 +30 in front with 225/35.. no issues on fronts but when i hit a big dip the tires would slightly rub in rears. no pull and im lowered about 2.5in all around
    - - - Updated - - -
    but you may need a spacer about 3mm or 5mm to clear your front brakes with a +40 offset.. sorry your +37 you should be good..
    Nov 13 2011
    b7 s4 avant
    Quote Originally Posted by AvantUa4 View Post
    - - - Updated - - -
    Got a pic?
    Jul 10 2015
    los angeles
    you wouldnt happen to have a direct rear or front shot showing the relation of the wheels to the car? I'd like to see how far out theyre going to potentially sit!
    Jul 23 2010
    arizona
    I can get them, but note my car is set up for my track wheels and my alignment is far from factory. When I was low I ran factory toe and caster but added negative camber front and rear. I wanna say -2.5 front and -3.3 rear.
    Jul 10 2015
    los angeles
    It looks like your current ride height in the front (or at least whats pictured) is almost the same as mine..and correct me if im wrong, but it almost looks like at this height the camber isnt necessary?
    Currently on 19x8.5 with 235/35 i rub in the rear on deep dips or if i accelerate hard from a dig. So Im expecting rubbing on the 9.5 for sure, unless it gives me just enough stretch to clear.
    Thanks for working on the pics! I appreciate it man!
    Jul 10 2015
    los angeles
    Quote Originally Posted by RAudiB7A4 View Post
    Lows
    thanks for the input! and pics!! I loove your car!
    Do you have any rubbing in the rear at all? as i stated above, i currently rub on the 235, im wondering if i should just get 225's and have no worries.
    thanks again!
    Nov 08 2010
    thanks again!
    Thanks. I have no rubbing issues front or rear. I used to run a 235 on my 9.5" rears and had no rubbing issues either so perhaps you need some stiffer rear springs. I'm running 7" 750lb Hyperco rear springs to stiffen things up a bit which helps. I haven't messed with any camber adjustments, no adjustable control arms or anything like that.
    Also, I should note that I have to run 5mm spacers to clear my front brake calipers. ET40 didn't provide enough clearance.
    DTM_B7_S4
