Results 1 to 32 of 32
Thread: Oil Meter
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Oil Meter
    Hello, looking at the Oil meter in MMI. If the gauge is half way between Min and Max, how much of a quart is it to make it full? How much have you all noticed?
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    The engine takes 6.6qt total, u can do the Math.
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Nov 08 2015
    Toronto, ON
    I thought it was standard not to add anything until the low oil message at which time you add a full quart?
    Someone can correct me if I am wrong.
    Jul 24 2015
    Quote Originally Posted by Factis View Post
    You can always top it off from what I know.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I believe the quantity between the min and max marks is one quart. So, at the min mark, the car is a quart low. So, you could theoretically add half a quart to make it full. But, there's no harm in letting the level fall to the min mark and then adding a full quart. Just make sure you top it off with an approved motor oil.
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Quote Originally Posted by justr0 View Post
    whoa there...do the math??? min means add 1 quart.
    If meter says half you don't add 3.3qt's! So don't do the math everyone.
    2019 SQ5, 2021 Q7
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Buy a dipstick
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    [QUOTE=justr0;11258490]The engine takes 6.6qt total, u can do the Math.
    Sent from my Nexus 6P using Tapatalk[/QUOTE I believe the capacity is actually 7.2 quarts ,but only one quart if at Min line. BUt dipstick would be best way to tell.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Not even close! So if it shows minimum, you add full 6.6 qts? LOL!
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Nov 08 2015
    Toronto, ON
    Yeah honestly I wouldn't fuck with this. Once it hits min, you will be prompted to add a full quart. Why bother with the guess work and potential problems?
    Jul 24 2015
    Quote Originally Posted by BigBluu View Post
    LoL i see what I said incorrectly, no u should not directly equat Min as 0qt of oil :-p ...I think it's .6 to 1 quart to be added at Min
    Aug 20 2015
    Louisville, KY
    Thanks for the replies. I knew the "do the math" post was nonsense.
    So, when the meter hit min, the car will prompt to add a quart? Has this been confirmed to happen? This would tell be my origional question about how much it takes to level off the gauge.
    Thanks guys.
    Nov 08 2015
    Toronto, ON
    My oil bar is just above min (1 notch) and I read the service manual as I was proactively considering topping it up, says once it hits min you will receive a notification on the MMI to add exactly 1 quart to bring it back up to full... seems like this is the way to go.
    Aug 20 2015
    Louisville, KY
    Sounds like a plan.
    Mar 21 2015
    No guess work with a simple dipstick
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    This
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Or just do exactly what the car tells you to do. If it prompts you to add a quart, add a quart.
    A dipstick tells you how high or low you are, not how much you'd need to add to fill. You could add a bit, check, add a bit, check, etc... or just wait until the car tells you to put in an amount. This isn't a 1987 Chevy pickup...the car is smart enough to know when to complain.
    Feb 17 2008
    Ashland, KY
    Yes it will tell you to add a quart once it hits low (happened to me a few months back). I also use a dipstick to make sure.
    2019 SQ5, 2021 Q7
    Feb 25 2010
    The City
    OP - Just curious, how many miles do you have and what kind of break-in did you do when new?
    Aug 20 2015
    Louisville, KY
    Bought used, 52k.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    I'm a dipstick according to some, but don't plan on using me to tell you how much oil you need. I'm just sayin' ...
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Well - I think it's a fair plan to check often and add when low - ie don't wait until he car complains..... Sure it's not the end of the world to wait - but IMHO any lower than full is less lubrication for the oiling system - and therefore causing additional wear - how much ahh who knows - but simply put best case is full oil always....
    So I check the indicator every few weeks and add the missing amount by 'doing the math' - but as noted the indicator as 1 Qt between empty and full.
    EDIT: Best plan is really adding dipstick - but I've been waiting to purchase a few things and haven't had the chance to pick one up just yet - so you get used to the process to use the MMI indicator.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Nov 08 2015
    Toronto, ON
    The point of adding a quart will not actually harm your engine from what I've read, it is what may happen progressively going forward assuming the oil continues to drop.
    Consider it relative to hitting the reserve fuel capacity in your fuel tank.
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    When my dipstick turned up, I dipped and nothing showed on the stick yet the MMI still indicated there was at least 1 bar. Dipstick all the way for me from now on.
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    What happens if you add more than 1 quart?
    Not that that I did, but what if someone listened to the advice about doing the math and added 3 quarts!
    Mar 21 2015
    Bad stuff can happen. Over filling can cause your oil to froth and get air bubbles in it which in turn can cause loss of lubrictation in critical areas. Less is better with this one.
    Dec 30 2012
    Mountain View, Ca
    would the MMI signal that you have too much oil?
    Mar 21 2015
    Quote Originally Posted by Ernie1060 View Post
    Don't think it does, a dipstick will though.
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Another vote for dipstick. I check my oil every other fill-up. Takes 30 seconds. The DIS will signal you with a loud BEEP that will scare the life out of you when the oil level reaches the minimum. It will then continue to annoy you every time you start up the car until you add oil.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    MMI will tell you if you are overfilled. The level on the MMI screen will also change as you top off the oil. I was changing my oil today and was confirming the oil level on the screen with my dip stick.
    I did overfill it by a little in the past and the car told me it was overfilled before I even started it. Easy enough to suction some out with vacuum.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Quote Originally Posted by Kczach View Post
    Good to know, thanks
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 10 2012
    DFW
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
