Thread: esp light
    Established Member Two Rings truea4b6's Avatar
    Aug 27 2015
    md
    esp light
    Recently my esp keep coming on every time I drive ? Does anyone know what went wrong ? Beside that I do have cel(blinking prnd trans range sensor ), could this cause the esp to pop ? Any input will be greatly appreciated !
    03 b6 3.0 cabriolet all stock ( soon to be a beast )
    Oct 02 2006
    Wadsworth,OH
    Seems like the two could be related. You really should scan the ECU with VAG-COM this will get you a list of all the codes from the ECU which will help lead you in the right direction of where to begin.
    Without some ECU codes all any one can really do is speculate.
    Jason
    Aug 27 2015
    md
    I got a scanner, nothing but trans range sensor malfunction .
    Oct 02 2006
    Wadsworth,OH
    If it's just a standard scanner it may not pull up ECU codes only CEL codes. ECU codes are actual diagnostic information - same info the dealer would have access to when servicing your vehicle.
    Jason
    Aug 27 2015
    md
    Is anybody around md area have vagcom that I can look up to it?
