Results 1 to 18 of 18
    Veteran Member Three Rings notn41's Avatar
    Jul 09 2013
    2012 V Rod Night Rod Special, 2009 GSXR 1000
    Las Vegas
    What size wheel spacers can I run on stock 2013 Audi S7 20" Wheels?
    I have a 2013 S7 with HR lowering module. lowered an inch or two.
    I am looking for 20mm front and rear, maybe 25mm rear if possible.
    I will be running stock Black optic split 7 spoke wheels 20" X 9" ET +37 offset.
    What is the widest I can go without rubbing when lowered?
    I am hoping for 15 front 20 rear.
    The ones in the picture are the exact wheels I will run and this one has 12mm Front and rear HR spacers.
    It looks like I could run 3mm more possibly in front and maybe 7mm more in rear. I just DONT want it to rub but love the low wide look.
    Thank you much
    Jul 09 2013
    Las Vegas
    Also, I am torn between ECS all black spacers and the H&R. Have heard good and bad with both. Would prefer the all black ECS but whats more important to me is the quality of the spacers for no vibration etc.
    Sep 19 2015
    Sprint Blue Audi S5: B&B Exhaust: KW V2's: APR Tune: APR Intake: Forged 360 Wheels: Falken Tires
    Arizona
    I have H&R 20mm front and 25mm rear. They are fine until you lower in which case you have to be careful of rubbing while turning. The suspension isn't stiff enough to handle the extra width when lowered. It's not a big deal, but you have to be more careful when driving aggressive or making sharp turns. Here's a pic with spacers, but not lowered.
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    Just a heads up, ECS has a sale on spacers right now so that might sway your decision. I just ordered some for my S6
    Jul 09 2013
    Las Vegas
    Ok so 15mm front and 20 mm rear you think??
    Jul 09 2013
    Las Vegas
    pictures added, of a 12mm spacer on a lowered s7 with the exact wheel set up I will have. The question is can I got wider? 15mm? or 15front and 20 rear? Look at the pics closely and estimate I guess. Wasn't my car was lucky enough to get photos.
    Oct 02 2006
    Wadsworth,OH
    The best way to understand which size spacer you need, is to simply measure from the top outside edge of your tire to the inner lip of your fender. This will give you the best idea on how much size you have to work with, and to decide on how much your wheels need spaced.
    Once you know that let us know and I will be able to recommend which size will be the best fit for your application.
    Here is a diagram that might help as well.
    Jason
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    Quote Originally Posted by notn41 View Post
    Thanks for sharing...Looks good! I think i'm going to go with 12.5mm spacers on my A7.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Jul 09 2013
    Las Vegas
    bump
    Established Member Two Rings UFmike316's Avatar
    Jun 12 2011
    DEXTER, MI
    i bought 10mm ECS and 15mm ECS spacers front and rear for my OEM RS7 wheels. same offset, so the results should transfer 100%. no vibrations from either. zero effect on ride quality. the 15mm front and rear did not rub, but were a little too aggressive for the look i am after, so i decided to stick with the 10mm. the 10mm still looked a little tucked in. 12.5mm would probably be perfect. most people who saw both preferred the 15mm look, but i preferred the 10mm. its just personal taste. i will be selling the full set (4 w/lugs) of 15mm ECS spacers (used for about 100 miles) in the classifieds for $100 once i get around to posting pics, probably next week. They will fit any C7.
    2014 RS7 / Phantom Black / Black Sport Seats / 21" aluminum 5 spoke wheels / aluminum optic pkg / red calipers / B&O / carbon fiber spoiler / AWE carbon intake / P3 Gauge in vent / Flat bottom steering wheel / Custom Black Alcantara Headliner / Eurocode Sway Bars
    Apr 15 2012
    AriZona
    Quote Originally Posted by UFmike316 View Post
    You have pics with the 15mm?
    Jun 12 2011
    DEXTER, MI
    no. i only had them on for a couple days.
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    For anyone looking like I was, here is my 2012 A7 with OEM 19". This is ECS Tuning 12.5mm front, 15mm rear. Car looks so much better now. It's not subtle.
    Before (stock):
    After:
    Active Member Two Rings sonjh81's Avatar
    Aug 31 2015
    Seoul, Korea
    12 front 15 rear sounds good to me.
    20mm is too wider for my taste.
    2013 Audi S6 4.0TFSI Quattro
    Havanna Black Metallic, Fully loaded
    APR Stage 2 ECU, APR Downpipes
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by sonjh81 View Post
    20 would no doubt be outside the fender well. I was worried about these I'm rubbing as they look very close. No rubbing as of yet.
    Sep 28 2009
    suburb
    i rubbed on 15 and 20 mm with vagcom drop. changed it to 12 and 15 mm and still slight rub.
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by flyfishing View Post
    I'm A7, not S7 fwiw.
    Feb 12 2019
    n54, B8.5
    Rhode Island
    Anyone else have spacers
    On stock wheels
    With pics?
