Results 1 to 10 of 10
    Deactivated One Ring
    Jun 21 2013
    Staten Island, NY
    Engine Spike misfire Jump then Check engine, TC, ABS lights come on 01 a6
    01 Audi A6 2.7t . Not to long ago this started to occur. I'd just be driving and randomly the car would jump, a spike maybe a misfire and right after the CE, TC, ABS lights would come on then stay on for a minute then go away. It's kind of strange. This happens very randomly. Sometimes once every 7 days sometimes 3 times a day. This usually happens during lower speeds but has happened while going faster (scary sometimes)
    Anybody have an idea of what this might be?
    Thank you!
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    This has happened to me on my b5 2.8 when my abs problem began. Unplugged abs controller and driving without abs and it happened once after that and i theorize its related to abs controller or something. quite honestly im not sure but i had it happen twice and nothing since then. its like a slight jitter, like a misfire and then back to normal.
    Sep 30 2015
    when i say it happened twice i mean it happened once before i unplugged abs controller and then once again after. Have to clean all my sensors. One is replaced already. Front axles are replaced so i know its not the front tone rings. That leaves abs controller, three abs sensors and two rear tone rings for me. Process of elimination i guess.
    Jun 21 2013
    Staten Island, NY
    Yea. I'd say it's more than just a slight jitter for me. It's a pretty heavy jump and definitely noticeable. I had a problem with the engine misfiring under rapid acceleration sometimes in the past but this seems different.
    Sep 30 2015
    It only happened to me when at idle in traffic and it felt like the rpms were dropping for a sec or two
    Sep 30 2015
    Happened again today, check engine light blinked, felt like a misfire. Going to check my plugs when i get home. They are platinum bosches with 20k on em. Was thinking maybe ignition coil is failing? Ignition system is different in our cars. 2.8 has one coil pack.
    Jun 21 2013
    Staten Island, NY
    I would check you're spark plugs for sure. I had a misfire problem that I thought were the coils but it ended up being the plugs
    Sep 30 2015
    For what its worth scanned the car and came up with
    Dont know if evap is related to our problem? Sometimes in the morning when i start my car you can literally hear the gas being sucked by the gas pump or through the tank and I read its my fault because i have poured gas in many times while running the car. Could that be related to our issue? Not enough fuel delivery and that causes hick up? I highly doubt my plugs are bad but ill check along with the coils and coil pack.
    Jun 21 2013
    Staten Island, NY
    Possibly. Post it up as a thread, see what people say
    Sep 30 2015
    My apologies for hijacking your thread, i just thought we had same problem.
