Results 1 to 13 of 13
    Established Member Two Rings yoshibishi's Avatar
    Jan 29 2015
    NC
    Stainless Steel Brake line burst!
    Has this ever happened to anyone?
    The stainless steel brake line on my front driver side burst last week.
    Here is a pic.
    2006 B7 S4 - Work in Progress
    2010 Evolution MR-Touring 340awhp/320awtq - http://imgur.com/a/eeIbp
    ETS Intake | ETS UICP | ETS V2 Quiet Exhaust | ETS HFC | Grimmspeed 3 Port | Seibon VR Front Lip | Rexpeed CF Hood Scoop, Side Skirts, Vortex Generators, and Lip Spoiler
    1992 3000GT VR4 450awhp/430awtq - http://imgur.com/a/dN2UG
    3sx Executioners (16T) | Dejon Intake | Dual Core FMIC | Turboback 3" Exhaust | 5Zigen FN01R-C | Too much to list..
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    What brand/from whom did you buy it ?
    Old Geezer, formerly known as Stud Muffin
    Jan 29 2015
    NC
    Previous owner had them installed, they were purchased from JHM.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    think it was rubbing against something ?
    Jan 29 2015
    NC
    Quote Originally Posted by jakeoboy67 View Post
    My shop took a look and it wasn't touching anything at all, which is why I am stumped at how this could happen. Never had a SS brake line do this before.
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Saw a thread a few months back with a guy in his (IIRC) B8 S4 that had a SS line burst on him while approaching and intersection. Scary stuff
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by yoshibishi View Post
    no friction marks, around the burst ?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Had one burst this summer in a B5 while in an endurance race. Downhill at 120+. Didn't know it was possible. Was pumping to try to get pressure back, not realizing I was pumping brake fluid onto the rotor.
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    it happens rarely under normal or mild track use. but i have seen it at alot on road course races, endurance and rally, its usually a small defect and under extreme load use and spike in heat it just pops.
    Established Member Two Rings B5man17's Avatar
    Jun 24 2013
    MN
    Someone burst a SS line at a HPED event going into a corner 100+, but he was able to save it. I purchesed SS lines before that event and never put them in, they are still sitting my garage after seeing that happen.
    Catless DPs, Magnaflow CB, 034 rear sway and end links, tint 20%, enkei ts9 pss (summer), BBS SR with R2 snows(winter), JHM R1 clutch and flywheel, JHM shot shifter, JHM shift knob, JHM tune, ohlins coilovers, stub trans and rear diff mounts.
    Jan 29 2015
    NC
    I replaced it with an OEM hose since time was of the essence. I don't notice any difference to be honest.
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Yup hoses blow, Factory and Aftermarket. All it takes is a minor defect that you can't see from the out side and eventually something gives, yours probably had a minor nick in the inner tubing and it was missed by the person doing the assembly. Buy a replacement and get on with your life.
    Jun 18 2009
    Phoenix, AZ
    Brake lines, OEM or SS braided, should be replaced every few years, and more frequently if you do any track time. Scary stuff.
    2017 Camaro SS 1LE
