Results 1 to 13 of 13
Thread: Oil Recommend
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Oil Recommend
    I have searched and read the threads on oil here on the forums. The place I am going to offers 5w30 Castrol Syntec Edge or 5w40 Synth Redline. Which of these do you all recommend for the normal 10k interval? The car will be mostly daily, with some getting on it around town and on back roads.
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    It's not a quick lube place, is it?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    I use Pennzoil Ultra Euro SAE 5W-40
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    I would just go to Valvoline and see if they have any hot deals
    Edit: Mobil 1 European Formula 0w40 all year round
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Quote Originally Posted by blbroo View Post
    Only if you use a Groupon.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Usa View Post
    Lets not condemn all Valvoline or like oil change centers for the severe problem created by one in Florida. But you never know who or what the experience level of the tech is when you go there. I guess since I have a 6MT, they would have a problem draining my DSG fluid by mistake! BTW, I uses either Mobil 1 European car formula 5-40 or Valvoline Syn Power 0-40
    Aug 20 2015
    Louisville, KY
    Hell no, I read that thread... It's a local performance shop.
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by SilverRings View Post
    HAHA!
    I use M1 0W-40 now, but did use the Castrol until my warranty was up.
    Oct 14 2012
    Empty...for now...
    SE PA
    I have used Castrol 5w-40 full synthetic - I forget exactly which "brand" (i.e. Syntec, Edge, SPT etc) but I know it meets the Volkswagen 502.00 which is required by Audi.
    Currently I am using Mobil 1 0w-40 full synthetic which also meets VW 502.00.
    SOLD 2015 Daytona Gray S4
    Aug 20 2015
    Louisville, KY
    Does the 5w 40 vs 5w 30 make a difference?
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Not really, but 40 would be preferred in the summer.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I use Motul for the 5k intervals between dealership visits, I believe they use Castrol Syntec.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Change it every 5000 miles....10,000 is too long. I use Mobile-1 0w-40, $26 at Walmart for 5 qt jug.
