Results 1 to 4 of 4
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    2.8 radiator fit 6 speed B5 S4?
    Hey guys,
    Quick question... does anyone know for sure if these radiators are interchangeable?
    Radiator developed a leak somehow and all the OEM S4 ones I see are around $300 shipped. Don't want to use autozone/advanced/napa radiators as I've heard they have fitment problems.
    I will fork over the $$ if I have to but if there is a cheaper OEM alternative I'd love to hear about it.
    -edit- post here talks about the auto radiator: http://www.audizine.com/forum/showth...1#post10945240
    Is it safe to assume the manual one will be the same?
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    there are at least 2 different versions of the S4 rad first off.... also I'm quite sure the S4 radiator is much bigger in capacity/cooling vs. the 2.8 and 1.8T units.
    Buy the proper rad, it's not worth trying to save $100
    Jul 01 2014
    'murca
    Well I was running a tip radiator on a 6 speed car (which is even smaller due to the cooling core for the trans on the bottom)... so this is a step up right? :P
    Thanks for the input!
    May 13 2011
    2015 BMW F30
    I have a used one if you just want to get by for now.
    shoot me a PM if you are interested.
    | Autospeed | JHM | Pure MS
