Results 1 to 40 of 61
    Registered User Four Rings mike@ngp_racing's Avatar
    Oct 29 2014
    Aberdeen, MD
    NGP Racing RS6/RS7 Stage 3 Turbo Upgrade Kit for 4.0T S6/S7 Vehicles
    To say this is our biggest hardware/software collaboration to date would be an understatement! We have teamed up with APR to offer you S6 and S7 owners the *Ultimate* performance upgrade. After extensive research and development we have created three upgrade packages built around RS6/RS7 turbochargers, 100 octane fuel, and APR software that can pump out a pin-you-to-your-seat 671hp and 708tq! The best part of these OEM+ upgrade is that you can choose from 3 "from mild to wild" packages :
    Basic Kit:
    This kit gives you the bare minimum requirements to upgrade to RS6 or RS7 horsepower and utilizes the existing factory airbox/intake.
    Includes:
    OEM RS6/RS7 Turbochargers
    All required hardware, gaskets, seals and hoses
    AMS Turbo Cooler System
    Utilizes existing factory airbox
    RS6/RS7 Intake Upgrade Kit:
    This kit is aimed at those looking for more of an OEM+ style kit, including the larger volume RS6/RS7 OEM airbox/intake.
    Includes:
    RS6/RS7 OEM airbox
    Full Upgrade Kit:
    This kit is designed for those that want the absolute highest performance potential from their S6/S7 and includes an AWE S-Flo Carbon fiber intake for maximum airflow to the turbochargers.
    Includes:
    AWE S-FLo Carbon fiber intake
    A detailed breakdown of the upgrade options can be found HERE
    More information on the software portion of this upgrade can be found HERE
    Nov 23 2015
    Oklahoma
    Just to be clear, is APR's software upgrade included in the pricing?
    Oct 29 2014
    Aberdeen, MD
    Excellent question. The pricing listed on our site for the three hardware kits does not include the software.
    Established Member Two Rings clintb's Avatar
    Apr 02 2014
    So it's ~$10K + Labour + APR Tune to get RS7 + APR Tune levels of performance?
    What's the average Labour cost in your experience?
    2013 S7 // APR 560HP|580TQ // AWE Black Diamond // 15mm Factory Drop // 20x10 TSW
    Dec 07 2014
    Mn
    Quote Originally Posted by mike@ngp_racing View Post
    What kind of testing, if any, went into determining the capabilities of the DSG being able to handle that kind of power long term? It's my understanding that the rs7 has the ZF because it's more capable of handling said power.
    Sent from my HTC One_M8 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Oct 29 2014
    Aberdeen, MD
    Quote Originally Posted by clintb View Post
    Labor time is coming in between 10-12 hours
    Quote Originally Posted by brianc21 View Post
    When we were dyno tuning at APR, we put down 690tq on 93 octane consistently with zero slippage. Ultimately we decided to back it down slightly, if only to provide that little extra factor of safety for long-term use (and we aren't greedy- 671tq isn't anything to sneeze at). You should have zero reservations about how well your transmission will hold up to the additional power.
    Dec 07 2014
    Mn
    When we were dyno tuning at APR, we put down 690tq consistently with zero slippage. Ultimately we decided to back it down slightly, if only to provide that little extra factor of safety for long-term use (and we aren't greedy- 671tq isn't anything to sneeze at). You should have zero reservations about how well your transmission will hold up to the additional power.
    May want to adjust the OP then, it states 708 tq.
    Established Member Two Rings Blairautomotive's Avatar
    Jul 11 2015
    Frisco Texas
    Pretty sure that is just the 100 octane file numbers in the OP
    2016 Audi S3 Viper Green Audi Exclusive, AWE Switchpath Exhaust, HREff15, Stoptech 380mm, Emmanuele Design Springs and Carbon Fiber, Eurocode Sways/links, APR Stage 3+
    2016 Golf R Oryx White DSG
    Master Guild Audi Tech
    Owner of Blair Automotive in Frisco Texas
    www.blairautomotive.com
    North Texas dealer for APR, AWE Tuning, VMR Wheels, JHMotorsports, 034, Eurocode, ECS Tuning.
    Oct 29 2014
    Aberdeen, MD
    Quote Originally Posted by Blairautomotive View Post
    That's correct, note made in OP
    Oct 29 2014
    Aberdeen, MD
    Up!
    Senior Member Three Rings ///M Traitor's Avatar
    Feb 05 2013
    Awesome job on kitting this together guys! I have a question about the exhaust side of things. Are these figures with the stock cats and exhaust? What are the differences going with aftermarket downpipes and exhaust? Is there any gauge as to which exhaust systems provide the best gains with the turbo upgrades? I currently have the AWE exhaust with stock catted downpipes..
    Oct 29 2014
    Aberdeen, MD
    Those numbers were made with test pipes flowing into the stock exhaust (with the mid-muffler deleted).
    With regards to gauging which aftermarket system will make the largest gains, keeping tabs on dyno graphs and what other enthusiasts are installing is the best way to know which exhaust may be "best". With that said, for the most part all of the aftermarket exhaust systems should be within a few HP of each other.
    Oct 29 2014
    Aberdeen, MD
    Up!
    Oct 29 2014
    Aberdeen, MD
    TGIF
    Hi Mike
    Was the test pipe made by APR or other brand?
    I notice your website mention 10.9 quarter mile time is that with 93 or 100octane?
    Thanks
    Sent from my SM-N9005 using Tapatalk
    2013 Audi S7 - APR stage 3 & TCU tune - RS6 turbo - APR Cast downpipe - Pilot Sport Cup2 295/30/20 - KOYA semi forge 04 (10.5kg) - RS7 front bumper/side skirt - Flat bottom steering wheel - Eurocode Überlegenes Stabilisatoren System (ÜSS) & front rear end link - 034tranny mount - Avery Satin black wrap
    Oct 29 2014
    Aberdeen, MD
    Jeez, it's March already?!
    Veteran Member Three Rings Fast4DR S6's Avatar
    Aug 28 2013
    MD/DC/VA
    Actually car has gone faster on 100 octane. This from a very reliable source
    2012 Golf R APR In-House Build - [U]European Car Magazine (July 2014 Feature Story)- SOLD
    2013 S6 APR/NGP Project RS6 Proto-type for all Stage 3 RS6/7 Turbos - Sold
    2019 Corvette ZR1 ZTK
    2021 Dodge Durango SRT HC
    2021 RS6 Unicorn Audi Exclusive Matte Paint
    Quote Originally Posted by Vol 4.0T View Post
    The car's best run was an 11.17 on 104 octane. It never ran 10's.
    where did you get the source mate?
    was it 11.17 then DA correct to 10.9?
    The owner of NGP read the numbers off the best timeslip to me on the phone.
    damn this is HUGE disappointment consider Apr stage 2 did 11.0 with race fuel
    wtf is the stage 3 for........??
    dunno why i bought the rs7 turbo for lol
    Established Member Two Rings TurtleHaste's Avatar
    Aug 29 2015
    Quote Originally Posted by playwithonehand View Post
    That was APR's first universal Stage 3 tune. You know how the software bumps go. Hell the stage 2 S4s / A6/A7s picked up I think over 50 hp from first to latest release.
    I think the confidence in the S6/S7 platform (engine cooling, transmission, etc.) as none have failed, will give the green light *no pun intended* for tuners to bump the stage 3 power up and out of "tease mode". Lol
    Their last Stage 3 tune was not only dialed back the first go around for warm and fuzzy sake, but since then, no slippage of clutch packs have been seen as far as I'm aware. Additionally, if these downpipes, and full bolt-ons are fitted, (especially with RS7 turbos) what would really keep an S6 from living in the 10s all day long? I think it'll happen. On 93 pump too.
    There is obviously more left in the tune of an S6/S7s fitted with RS7 turbos. Just waiting till someone releases an updated tune for a full bolt-on stage 3.
    Speaking of, Anyone going to the track this weekend? If I'm able to go, I'll get to test the 93 pump stage 3 setup with this intake. Milltech downpipes for now, I can compare trap speeds when I get the APR downpipes. Should be *something there*.
    2014 S6 Stage 3 (RS7 turbos) / Roc-Euro intake / Milltek downpipes + resonated Valvesonic exhaust / AMS turbo cooler / 034 Motorsport trans. mount kit / APR ECU/TCU tune
    Aug 28 2013
    MD/DC/VA
    Very few actually pioneer ahead and share........
    Everyone seems to be so negative these days. This is a work in progress and the few leaks of information folks share they get slammed purely on numbers, not the conditions or test parameters. No one has stated what the best time is, because it has not been tested.
    I applaud the few on here who lead the pack and actually share......
    Instead those with very little vested are suddenly the experts above those who have been testing and testing the platform for over a year.
    - They should of kept the car alone when it was Stage 1 with Cat Delete on 100 file when it ran the fastest times. Hell it was close to "sciblades" time after hist RS7 turbos swap. What a waste of $$$$
    - Below referenced time from NGP owner on a day that was close to 100 degrees, high humidity, and we were testing an off the shelf cooler upgrade that actually proved to be less efficient then the OEM version causing timing to be pulled and significant powerloss versus the RS7 Stage 1 with its OEM cooling keeping temps within tolerance. If you factor all that is rather remarkable how well the car performed versus the Stage 1 RS7.
    Not sure how many will actually step up and do this, but all I have to say its one hell of a ride and money well spent. Open your wallets and get in line
    This platform as some stated earlier can easily run in the 10's and trap over 130mph when released if thats your passion if launched and hooked up correctly. This is a luxury family saloon not a drag car, so your risk level for having something break goes up significantly.
    FINAL test for me since I am not a diehard 1/4 guy, is comparing RS7 versus S6 Stage 3 (Cooling Upgrade and DCT tune) in a WOT 1 Mile Airplane Ride.
    Details coming soon. Cheers - the Greek
    Oct 29 2014
    Aberdeen, MD
    Happy Tuesday
    Oct 29 2014
    Aberdeen, MD
    Hump day
    Oct 29 2014
    Aberdeen, MD
    Hump Day
    Oct 29 2014
    Aberdeen, MD
    TGIF
    Oct 29 2014
    Aberdeen, MD
    Caffeinated bump!
    Oct 29 2014
    Aberdeen, MD
    TGIF
    Aug 29 2015
    I'm curious when IATs are not an issue, (assuming AMS cooler) what the traps will be on a stage 3 S6 with all proper supporting hardware on a 104 tune. waiting... If I can get out there and do it I will. Just been busy.
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    I will try it once I finally get my install done.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Veteran Member Three Rings KnewJack's Avatar
    Apr 28 2016
    Saw this is on RSW site regarding C7 S6 stage 3 RS7 turbo setup and APR tune (scroll to bottom for time slips).
    http://redlinespeedworx.com/audi-s6-...-attacks-1320/
    Why are these times not in the C7 S6 database? These would be the fastest C7 S6 times on record, unless I'm missing something.
    Aug 29 2015
    Those are my 3 time slips. I think they accidentally put my slips up there on their latest S6 build. Mine was the black S6 they first put up. I'm sure it was just a mistake.
    Apr 28 2016
    Quote Originally Posted by TurtleHaste View Post
    Man, thanks for clearing that up. A C7 S6 trapping 130+ on stage 3 would truly be drool worthy. RS7 makes more sense, that car is awesome! They really need to change the title or take those slips down, very misleading.
    I'm guessing you would probably need the hot cams out of the RS7 to even approach that kind of performance with an S6.
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Quote Originally Posted by KnewJack View Post
    Turtle's signature says he has an S6, where do you get RS7 from?
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Aug 29 2015
    Haha. Thanks. And yes. It is my 2014 Stage 3 S6. Not an RS7. :-)
    Jul 07 2015
    Midwest
    Thought it was an S6, very nice. How are you getting times that are so much better than the other stage 3 people, even APR's advertised times?
    Dec 14 2011
    Dublin, OH
    Quote Originally Posted by hubris View Post
    There's not that many stage 3 S6 people out there. At least ones that have the full setup: turbos, intake, coolant upgrade, downpipes and ECU/TCU tune. And the field narrows even further for ones who have track slips.
    Jul 07 2015
    Midwest
    Quote Originally Posted by Dguth View Post
    True, I guess I was mostly thinking of fairbird, who IIRC had trouble even breaking 10s?
    So far these the people I know did stage 3 upgrade with slip:
    Spero S6 - 11.188 - 127.05MPH - 93Octane
    Fairbird S6 - 11.043 - 126.52 - 93Octane
    Turtlehaste the current record holder :) 10.746 at 130.90 with 104 octane.
    Myself S7 ran 11.153 - 128.01MPH 93octane, I just got the APR TCU RS7 shift map so hoping to get into 10s this week with 93 octane
    Aug 28 2013
    MD/DC/VA
    Awesome Work Guys!
    Always knew that this setup has the power to get our cars into the mid 10's! Great Job to all you 1/4 mile junkies
    Apr 28 2016
    I misread his sig. Just saw RS7 at a quick glance not realizing it was RS7 turbos! Doh! So really there was no mistake on the website, an RS7 turbo equipped C7 S6 ran those times. Very impressive. Any video of the run? Also I love the color of your car too, TurtleHaste, what is it called?
