Results 1 to 8 of 8
    Sep 18 2015
    Houston
    New SPEC Stage 2 Clutch
    Preface: I'm terrible with the search tool.
    Hey Folks,
    I just recently had a SPEC stage 2 clutch put into my B5 S4 and am wondering about some noise. I understand there is going to be some chatter there, but when coming out of first there is a wicked grinding noise.. but only for like the 1st 10 minutes or so. Is this just my pressure plate warming up? I'm only like 150 miles into the break in, is it possible this will just go away? doesn't seem normal.
    thanks in advance for all advice and flaming at my lack of search tool ability.
    Feb 18 2013
    Louisville
    The sound happens when you're shifting from 1st to 2nd? Or when you're starting from a standstill in first?
    Sep 18 2015
    Houston
    stand still in to first. I thought at first it was just getting used to the new choke point, but it goes away after a bit of driving so I'm pretty sure it is not user error.
    edit: no noise in any gear once rolling.
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    Stock fly wheel?
    Sep 18 2015
    Houston
    It's a 9lb lightweight flywheel. I got the kit frhttps://www.ecstuning.com/Audi-B5_S4...tch/ES2576032/
    Feb 13 2004
    07 F430, 07 997 C2S,11 E90 335i, 00 S4, 93 Corrado SLC
    2 car lenghts ahead, TX
    Hmm. I'm leaning towards flywheel or something with the install possibly. I'm not sure how much different the current SPEC Stage 2 clutches are now, I installed mine (hate to say) 12 years ago and it never made the noise you describe. Worked like a champ.
    The R
    Jul 07 2009
    Alberta, Canada
    Pilot bearing installed in new flywheel?
    Sep 18 2015
    Houston
    Hey guys, talked to SPEC and got it up on a lift at my buddies shop, we went over everything and apparently they are notorious for the clatter and I'm just being impatient with break in. I'll let you guys know after a few more miles if it persists!
