Results 1 to 40 of 40
    Aug 28 2014
    Cleveland, OH
    HPFP or Downpipe if you had to do one?
    Looking for feedback on above subject line. Looking for continued improvement on low end results. Would love to do both but at this time have to choose one. APR stage 1 otherwise stock 2009 B7A4 Cab
    Thx
    Veteran Member Four Rings Shanster's Avatar
    Jun 02 2011
    2014 B8.5 Allroad, 2016 5th Gen Toyota 4Runner
    Maine
    I'd go both
    Aug 28 2014
    Cleveland, OH
    Wish I could but I cant pick one? and why :)
    Thx
    Jun 17 2013
    jersey city nj
    DP. It will improve spool time on the low end. HPFP mod will yield you slight upper midrange to high end rpm gain.
    Veteran Member Three Rings konarider94's Avatar
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    To get to a point where fueling is the limiting factor you should have the downpipe first. If you don't have a need for more fuel supply upgrading the pump wont do anything.
    2018 A5 S-Line Manual
    Aug 28 2014
    Cleveland, OH
    Much appreciated......Like the list of your improvements...impressive and an avant no less NICE!!!
    Mar 24 2013
    Oakdale, CT
    I would vote hpfp. I noticed a decent improvement in mid-range power even without a tune. My downpipe went on with the new turbo, so I can't say how much gain there was from it.
    -Adam
    Dec 28 2011
    14 EBR 1190SX
    kalamazoo, MI
    That seems unlikely. In order for that to happen your car would have to be leaning out or experience fuel cuts for some reason. This is my AFR with the stock pump. The ability to push more fuel isn't going to help anything.
    Mar 24 2013
    Oakdale, CT
    Unlikely as it may be, my powerband definitely felt "fuller" and I'm not the only one who has noticed this.
    -Adam
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by konarider94 View Post
    X2 I dont see why there would be gains from an HPFP if you dont have the tune to use it. Removing the oem bottle neck cat and replacing it with an HFC in the other hand will be significant.
    *****I sell in USD*****
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    Quote Originally Posted by vce1232000 View Post
    This^. Unless you are having hpfp issues a HFC will bring more low end gains for less cost.
    Kevin
    2015 A7
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    If you don't have a HFC or TP I'd go with the HPFP, DP may feel better, it just won't do justice until you open it up between the DP and the Turbo
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by Reggie Dunlap View Post
    Thx
    I've done both, plus some other things... I would highlight suggest opening up your exhaust system first.
    Think of your engine as a big air pump; ultimately, its main job is to get air in and out as quickly and efficiently as possible. The quicker air exits, the quicker it can enter. Opening your exhaust is the very first mod I would suggest; go with a test-pipe if you can. It'll save you the hassle of there being a limit of you decide to go bigger later.
    Once your engine is inhaling and exhaling efficiently, you can start adding fuel. You'll see much larger gains with an HPFP and tune with a free breathing engine. I'm not going to shill one test pipe over another, but mine passed tight Ontario emissions standards without an issue.
    And let's face it; you can buy a new test pipe for half the cost of a used HPFP...
    Cheers!
    _____________________________________
    B7 2.0T 6MT Avant. JHM test pipe, APR Carbonio Intake, 034 TIP, S3 injectors, APR HPFP, Stasis Cat-back, Eurojet billet VC, 42DD catch can, OEM black optic RS4 grill, RNS-E, JHM 93 Octane Stage 2, R8 Coils, RS4 rear sway bar, Stern engine mounts, Akipol rear diff mount.
    More to come.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jun 27 2011
    The HPFP will only help if you get a tune that will take advantage of it. Its not just a magical "swap it out and get 20hp on the top end" thing.
    Just wanted to clarify since I hadn't seen it mentioned.
    A DP will help because it removes a restriction behind the turbo and lets it spool quicker.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Nov 15 2011
    Ahem :P
    Quote Originally Posted by Axis View Post
    Jun 27 2011
    Ahem :P
    Pssshhh. Ain't nobody got time to read posts!!
    -CP
    2017 Q7 3.0t
    Oct 24 2015
    Perth, WA
    ^lol
    My respray thread
    Jun 17 2013
    jersey city nj
    U.......
    Mar 24 2013
    Oakdale, CT
    Just buy a used test pipe and used hpfp and don't look back.
    -Adam
    Jun 17 2013
    jersey city nj
    It mite be OP lucky day to +Save $$$$$$. ktish is parting back to stock. He's selling JHM HPFP mod, JHM Y DP, JHM Test pipe, Stock S4 exhaust on the reasonable. Go Stage 2+ for fraction of the $$$$ http://www.audizine.com/forum/showth...eadlights-cash you can this thread to PM him
    Mar 01 2011
    Nanuet NY
    why not just save your money? you wont gain much with just those two. If you get any of those two, you will need a tune and your back to spending money again....
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by reno808 View Post
    Be quiet mom!
    -Adam
    Jun 17 2013
    jersey city nj
    He has APR tune. All upgrades up to 2+ from stage 1 would be no charge from APR
    Oct 24 2015
    Perth, WA
    MOAR MODS!!!
    My respray thread
    Jun 27 2011
    No charge from APR + shop fees (usually $50-100)
    -CP
    2017 Q7 3.0t
    Jun 17 2013
    jersey city nj
    The shop I use http://www.driveautoworks.com/ doesnt charge labor to tunes or upgrade them if free from APR
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Okedokey View Post
    MOAR MODS!!!
    Go BIG or Go Home. Is what I say
    Jun 27 2011
    Lucky. My local APR dealer (achtuning) charges $50 for shop time for tune upgrades.
    -CP
    2017 Q7 3.0t
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    What use are getting the mods if the software isn't there to back it up?
    As much as I would love to take his money, $600 would be better spent just getting a stage 1 tune from JHM. They'll give you a free upgrade to stage 2/2hpfp too
    Oct 24 2015
    Perth, WA
    He already has a tune.
    My respray thread
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by ktish View Post
    "APR stage 1" otherwise stock 2009 B7A4 Cab
    ....lol
    Nov 05 2012
    Well aware my friend.
    https://www.youtube.com/watch?v=drZnBKY-p9E
    Mar 24 2013
    Oakdale, CT
    He meant that APR's tune sucks.
    -Adam
    Veteran Member Four Rings brandonpham's Avatar
    Dec 07 2014
    Belleville, NJ
    Primemotoring doesn't either. Always in my area man!
    Jun 27 2011
    Yuuuuuuup.
    -CP
    2017 Q7 3.0t
    Jun 17 2013
    jersey city nj
    Mar 24 2013
    Oakdale, CT
    Says the guy jumping ship from APR to JHM lol
    -Adam
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Speaking of which.. When are you going to send me that code readout from VCDS, vce? lol
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Jake@JHM View Post
    I figured you come out from your cubicle soon with that one...lol Actual Ive been so busy on other projects
    http://forums.vwvortex.com/showthrea...-VW-Rabbit-GTI
    http://forums.vwvortex.com/showthrea...laway-Re-Build
    Im going to Drive Auto Works on Thursday to get the coding needed. Seems there's not enough time in the day to get this all done
    Aug 31 2011
    Lathrop
    Haha I just need a fault code read to get your ECU PN so i can upload you a file
