Results 1 to 34 of 34
    Senior Member Three Rings B6_A4_Kid's Avatar
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    B6 a4 1.8t won't start, really need some help.
    Alright guys I'm a new kid around here, I just got my own a4 it's an 04 Quattro with 131k on it. I have had it for a week. My car did not pass emissions and threw the code for a bad Evap purge valve. I received my new one today, a Bosch from ECS, I also decided to slap in some new plugs. I get all my new parts installed in 10 minutes, fire it up and went to grab lunch. Came home parked her in the garage and shut it off. About 7 hours later I was going to go catch a movie with some buddies, went to start it up, nothing. It will crank forever, I can hear the fuel pump, and it's getting fuel because the plugs are wet. I put a plug in a cool pack and positioned it on the valve cover and cranked it, no spark. Them I put the old plugs back in, same deal, nothing. I am kinda thinking it might be the speed sensor, but not sure. I can take a video of it trying to crank once the battery is charged again.
    Jan 24 2010
    Paramus,NJ USA
    Hmm weird check for faults.Was the timing belt even done on the car?It could be a speed sensor but even with a bad crank sensor it should still pickup the cam sensor and know when to fire the plugs and injectors.No fuel leaks??My instinct tells me bad fuel pump but you would need to check for fuel flow before rail while cranking the car.
    Ziddy Autowerks
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    The car fax showed an Audi 100k maintenance, I figured that was the timing belt
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I ordered a cheap vag com cable and it won't be here until Tuesday. The car had its 100k maintenance done by Audi, not sure if that means timing chain or not. Still not sure if it's the fuel pump because I can here it, and the plugs are wet. Not a single leak is coming from anywhere on the car. The only thing is my coil pack harness is pretty effed up, had spots with bare copper, taped it up as best I could but didn't make a difference. I took a video but I'm not sure how to post it up here
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I believe I found the issue, I must have been looking right passed it. On the left side of the engine, there is a metal line that runs to the kombi valve, and at the front of the motor it has a 90 degree fitting to go down to I believe the SAI not sure. But that fitting is broken, not sure if that is the current problem. But it is an issue, another issue is I can't find that fitting anywhere. I'm thinking I'll have to go to the stealership
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    The SAI won't stop the car from starting, it will throw a code but won't prevent starting
    If it was the crank sensor the car should be able to start at around 2 or 3 trys
    It's easy to check if the timing belt is good by removing the upper timing cover (only clips hold it) and starting it, if the belt spins the cams it's good, plus you can inspect the belt for piece of mind.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    what do I look for with the timing belt? It won't start
    Apr 22 2012
    Fremont, CA
    When the starter cranks it's spinning the crankshaft which spins the camshafts via the timing belt, if the timing belt was broken your cams will not be spinning while the motor is cranking
    If your by yourself you can mark the camshaft sprocket, try to start the car for 1 sec or less then check to see if the mark moved
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Sorry to be a noob, which sprocket is for the cam?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Timing checks out, I think my next step is to order a new coil pack harness and see if that fixes it. I am absolutely get zero spark and it only happened after I change my plugs, as I pulled the harness of I could hear the plastic inside cracking. Hopefully I can have one overnighted to me
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Have you checked your engine management fuses? They are under the fuse panel on the left end of the dash. Open the door and you will see the panel .There are four engine management fuses. 29, 32, 34 and 43.
    Your cracked coil pack harness may have shorted out and blown one of them.
    Veteran Member Four Rings V70R's Avatar
    Feb 14 2015
    PDX, OR
    Check the fuses. Had a very similar issue on an '02 1.8t, coil harness was the culprit. Fuse 29 I believe is the 12V+ for the coil packs, but check them all.
    Xlite w/ 11spd Campy Record- 2005 Dolphin Grey Ultrasport Avant 6MT-- 2003 S6 — 2007 XC70
    Jan 24 2010
    Paramus,NJ USA
    I believe the harness for coils is part of the entire engine harness.Is the ground attached to the valve cover???should be a 10mm nut
    Like others have said check fuses.Also which plugs did you put in the car and are they gapped correctly?
    Ziddy Autowerks
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I have checked the fuses numerous times, and I pulled the ground on the valve cover and cleaned it. Trying not to fray the wire, I'm thinking about pulling all of the old brittle plastic and just wrapping in electrical tape to see if I need a new harness or not. Imo it has to be an issue with the coil wiring because it only happened after I changed the plugs
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I put the same plugs my bro runs I his b6, bkr6e gapped to .30
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I think in my tired swing that was yesterday, I was misreading fuse 29 for the one below that. I just went through this morning and pulled each one and sure enough 29 has been popped. That fuse is for the coils so I taped up all of the bare copper I could find, now I need to let my battery charge up and see if she'll fire. Fingers crossed
    Apr 07 2011
    Like OG said, if the engine management fuses are popped then it's definitely being caused by the coil pack harness. Get that fixed ASAP.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Well i put a new fuse in and it's still a no start. I'm at a loss here
    Established Member Two Rings Northern_B6's Avatar
    Feb 20 2013
    CANADA
    Order up a new coil harness.
    Are the coil packs themselves in good shape? What revision letter coil packs are in the car?? Post up a part #
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Not sure which number you want off of them. Two are vmq 2 and one is vmq 5 and the last one is vmq 14. I have ordered a harness but I really need this car to get to work and school.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    06A 905 115 D
    3 of them are from 09 and one is from 10
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I really need help guys, I have to get this car going with a temporary setup until my parts get here
    Feb 14 2015
    PDX, OR
    If fuse 29 is popped, almost guarantee that it happened again while trying to start the car. You have a short in the positive feed to all your coils, you can try to find it by removing the boots at the coil pack connectors and insulation.
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    It was odd because the second go around the fuse didn't pop. Did I maybe screw up my coil packs?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I ordered new 4 pin adapters and they are supposed to be here by the end of the week
    Jun 30 2008
    Erie, Pennsylvania
    Check for spark. It's easy. If you have spark, the harness is good enough to work for now and your problem is somewhere else.
    Apr 22 2012
    Fremont, CA
    If the fuses are still good and you fixed the coil harness enough to where you no longer have any shorts, for now at least.
    Check for spark, if you have it, then maybe the engine is now flooded from all the start attempts?
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Checked spark, still nothing. I'm getting pretty frustrated at this point
    Dec 28 2006
    Western Maryland
    Your "D" coil packs are the latest revision. Once you get your cable in tomorrow you may find a code P0322. Clicky click®
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I tried to download vcds lite, but it isn't working on my computer
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    I am thinking it is the speed sensor. But I am confused about it, I am going to replace it anyways because that's how I roll, but which is it for my b6 1.8t Quattro with auto trans. I am looking at speed sensors, but for some reason I think it might be the crank sensor. Not sure maybe someone can point me in the right directing. One actually has wire, and a plug. And one is a solid plastic piece with a plug
    Jun 30 2008
    Erie, Pennsylvania
    So you checked for spark, and you have none? Don't stop there, you have to continue to trace the fault back to the source.
    There are 4 wires to each coil pack connector: 12v+, Ground, Ground, and a 5v square wave trigger. Figure out which signal you are missing. Then continue up the circuit to find out why. I'd start with making sure the 12v+ is present with key ON.
    Or just start throwing parts at it. That's always fun. <sarcasm>
    Feb 14 2015
    PDX, OR
    Grab your DVOM and check the ground and power supply wires at the coilpack connector. See if there is any resistance on your main ground wire, and whether or not your coils are getting power to the 12V feed wire. By the way, turn the ignition to auxiliary when you are checking for power at coilpack connector. If you do not have any power at the 12V feed wire, re-check fuse 29. Let us know what you find...
    Dec 07 2015
    89' Land Cruiser
    Salem, Utah
    Well thats exactly what I did, I went to Oreillys and bought a crank shaft sensor. I hooked it up with the DIY that old guy posted (thanks) and she fired right up. No CELs running better than ever
