Results 1 to 4 of 4
    Dec 13 2015
    Illinois
    Banging noise when turning wheel left and right lock
    I'm looking at buying a 04 A4 3.0 Quattro. While test driving I hear a single bang or knock when turning the wheel all the way left or right. Is this a big problem/expensive. The vehicle has 40k miles.
    Apr 15 2014
    Ottawa/Gatineau Canada
    No way to know.
    Jack it up and have a look at all the suspension components. Or you can pay a hour labour to have a indi VW shop inspect it for you.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Dec 05 2007
    Most likely ball joint of control arm or tie rod, or cv joint. My car does the same, and have been too lazy to figure which conponent it is (passenger side). Kind of dangerous, actually.
    Jan 06 2009
    While moving or while stationary?
    It could be as simple as the bellows over the inner tie rods collapsing on itself making a loud singular pop noise. As they age and dry out they do that.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
