Originally Posted by
Silverbullet S4
This has been covered many times and is getting way off topic but, while this worked in the past, don't count on it working anymore. Audi pushed some notice to hook every vehicle up for a rectal scan during every service....regardless of what the vehicle is in for. The alleged hidden tunes aren't necessarily hidden anymore either, and this includes removing the flash before going to the dealership. There are mixed results but if you have a tune, assume you're TD1'd and hope for the best. In short, if you take your Audi to a dealership odds are they will hook it up and if you have a tune, odds are they will see it and flag you. Doesn't matter if you ask/tell then not to hook it up first. If you have a dealership that's working with you and never hooking it up to the scanner, you're lucky and in the minority.
You do realize I'm a tech at a Audi dealership right? It is pretty much totally up to the technician and no one else, if I am not notified that the car is flashed, I will perform work as if it is not. I generally ask the moment I see any inkling of mods on the car that the customer be notified and asked if there are any modifications on the car. Like I stated before, down to the Service adviser doing the right thing. Just don't expect any engine warranty work on your car to be completed, or any software updates / recalls that involve flashing. Also, I'm not saying every dealership is perfect and will do this for you, but there are plenty out there that will do the right thing by you.
AudiTFSI3o3
lol fine i'll take that loss, but what about the member here who went in for service and one of the techs hooked his car up for the airbag module recall? he got TD1'd immediately.
what everyone here is saying is unless you have some sort of close relationship with your service advisor, which i'm sure not all of us here do, even something as simple as a service interval with Audicare could still result in TD1.
This is correct, any flash, any check engine light that involves the use of Guided fault findings or Flashing through guided functions will do this. (Every time a flash is performed there is a check sum performed of all the modules, and guided fault findings leaves a detailed log of every module.)
