Page 1 of 9 123 ... LastLast
Results 1 to 40 of 336
    Jul 21 2004
    South Florida
    Just another reason not to take your S4 to an instant oil change shop....
    I already blame myself enough and am aware what I did was stupid by not taking my car to a more trusted shop or doing the work myself but i'll share this post anyways and be ready for the flaming :(
    I was looking through Groupon and happened over a $49 deal to get a full synthetic oil change at the Valvoline Instant Oil Change place. [edit] Note, I usually do the oil changes myself but its been a little hectic lately. We are selling the house, things are packed up, yada, yada. So I figured, why not do an added 5K interval change at such a cheap price and i'm driving around anyways near there. I cant buy the parts that cheap and it's Valvoline so whats to lose right? ...and there is where my mistake lies and what turned into a 4 hour ordeal that involved police.
    I pulled up to the oil change place and stayed in the car. A couple minutes into the change I feel a jarring / ripping sensation through the floor of the car. I'm thinking, "Hmmm, I hope they know to slide the aero belly pan to the rear to let it drop down instead of pulling on it." ...I make a mental note.
    So now they are at the stage where the person up top starts to pour in the motor oil. He starts to poor it in and stops pretty quickly yelling to the guy below to make sure he drained it all out as it is overflowing. ... Mental note number two. Hmm.
    A few minutes go buy and I call the manager over and mention to him that I would appreciate it if he make sure all the 1/4 turn fasteners are put correctly back into place because they are very expensive to replace. He smiles and assures me he will make sure that happens.
    Now the oil is supposedly back in the car and we are about to close our transaction. I'm standing at the front of the car and i'm staring at a 1/4 turn fastener sitting on the ground under the front of my car. I'm waiting...waiting..waiting for someone to pick it up to put it in or to tell me "You're all set." ....and sure enough I hear..."You're all set; you are good to go." So I bend over and pick up the 1/4 turn fastener and ask to talk to the manager.
    The manager comes over and I point out to him that his person just left $20 worth of fastener of mine on the floor and I'd like to go into his pit to see what else is missing. He takes me down into the pit where I see this...
    I'm looking up at the car at first and I see the DSG drain plug right there and there is DSG fluid all over it and dripping. I'm thinking "Why can I see the DSG drain plug? Theres supposed to be an aero pan covering this?" and i'm also thinking..."Oh crap, they drained the DSG fluid."
    As I keep looking up my brain starts to register what it is seeing. Holy crap, this guy cut my car into pieces. My aero pan has a huge hole cut into it. I'm standing in the oil pit now with the tech and the manager and I ask the tech if he did this to my car and if he drained my DSG fluid. He says absolutely not. Well since I am under my car every week and I know no one else was under my car I'm finding that very hard to believe. So I took it upon myself to walk around their oil pit until I found two of these..
    Yeah, sitting in their trash can are two pieces of my aero pan he cut out. At this point i'm thinking that I need witnesses, and alot of them. I call my wife and I called the police so I could at least get a report.
    It looks like this is what happens...
    1. Employee cuts hole in transmission aero pan and drains DSG fluid.
    2. Tech tries to put in motor oil and it overflows all over the engine because no engine oil was ever removed.
    3. Tech and manager were going to let me drive on my way with no DSG fluid and massively overfilled engine oil in which case id likely be out an engine and transmission.
    I had the car flat bedded to Audi and will await the damage on MON. I'm worried they tried to cover up their mistake of draining the DSG fluid and put some no name brand automatic transmission fluid in the DSG in which case I dont even want to know how I can get Audi to test the fluid in there to see if it is non OEM.
    I have learned my lesson. This sunday sucks.
    Mike
    UPDATE 1:
    On 12/14/2015, after business hours I sent the following letter to Valvoline...
    Good Evening,
    My name is Michael XXXXXXXXXXXXXX, owner of the 2015 Audi S4 that was damaged at the Valvoline Quick Oil Change center at 9012 FL A1A Alt, Palm Beach Gardens, FL 33403.
    The following occurred on 12/13/2015
    1. I pulled my car into the right side service lane. While sitting in the car I felt a sharp jarring motion of the car.
    2. A few minutes passed and the technician on the top floor came over to my car with two large jugs presumably filled with motor oil. He began pouring the motor oil into my car and stopped relatively quickly shouting below indicating the oil was overflowing.
    3. I was asked to step out of my car so they could raise my car up in the air in order to remove the front (engine) belly pan.
    4. After a few minutes the technician poured the rest of the oil into my engine.
    5. I asked the manager to be certain all 1/4 turn fasteners were re-installed as they are quite expensive.
    6. While standing in front of my vehicle I was told my car was completed and ready to leave. I was advised to start my car to check for oil pressure and I complied by starting my car and revving the engine lightly. I was advised I could drive my vehicle home.
    7. I noted a 1/4 turn fastener located on the ground under my front bumper and brought it to the managers attention. I asked him to view the bottom of my car with him to inspect for further neglect.
    8. Upon going into the oil pit and looking up at my car I located an exposed DSG transmission drain plug with wet transmission fluid leaked around it as well as on the lower chassis brace next to it. I noted the transmission aero belly pan had been cut into and destroyed. See attached pictures.
    9. I asked the technician why he did this damage and he claimed he did not. I looked into the garbage can down in the oil pit and found the two pieces of my car that were cut from my car in this trash can. See photos.
    10. I contacted police who responded: See North Palm Beach Police Department report# XXXXXX
    11. I was advised by officer XXXXXXX that he had secured a confession from the technician admitting to damaging my aero. The shop manager and owner later admitted to "cracking" the DSG transmission drain plug. I was advised by North Palm Beach Police I have the right to press charges.
    12. The vehicle was flat bed towed to Audi of West Palm Beach. The technician found the DSG transmission to be missing all but 1/2 quart of fluid. The engine oil was not filled completely as 2 quarts had been poured into the engine prior to the Valvoline technician draining the engine oil (he had instead drained the DSG fluid). Please see the invoice for which I have paid in full.
    Please submit to me payment in full within 7 business days. Please confirm receipt of this email.
    My address is:
    XXXXXXXXXXXXXXXXX
    XXXXXXXXXXXXXXXXX
    I can be reached M-F from 7:30am until 4pm at XXXXXXXXXX and after 4pm and weekends at XXXXXXXXXXXX. My preference is email communication.
    Thank you.
    Michael XXXXXXXXXX
    On 12/15/2015, the following morning, I received this reply....
    Subject: Transmission Drained
    Updated Information:
    Hello Michael,
    Thank you for taking the time to contact Valvoline Customer Care and your patience in addressing this matter. The documentation for your claim has been successfully received. It has been attached to your claim (claim# 1-227256) and you will be issued a reimbursement check in the amount of $1,442.48. You will receive the check in the mail within 7-10 business days.
    If I may be of any further assistance, please don't hesitate in contacting me.
    Sincerely,
    Melissa
    [email protected]
    800-327-8242 opt# 2
    859-357-5227 fax
    Thank you,
    VIOC Customer Care
    UPDATE 2:
    On 12/18/2015 I received a phone call from the Valvoline regional manager. He stated he was aware a check had been issued but he wanted to follow up with me regardless just to make sure an apology had been appropriately expressed to me and wanted me to know that the employee had been terminated. He wanted me aware that Valvoline does not tolerate this kind of service. I expressed my appreciation for him reaching out.
    As far as responses go from corporate, I am impressed with their response time and their response itself. It appears that as long as you do your diligence and make sure you document document document and make sure you observe observe observe as any errors are made, Valvoline is willing to step up and provide compensation for their errors. Reflecting on this, I suppose that can be a positive aspect of going to a quick lube that is backed by a more reputable company. You actually do have the opportunity to observe the oil change as it is happening. If I were at a shop and this was done back in a bay on a lift somewhere out of my sight, I may have never noticed the issue until my car stopped running days later. I know I dodged one this time.
    Mike
    2018 Audi S5
    Gone-
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Damn. That's brutal. I'm sorry man.
    Mar 21 2015
    That might be one of the worst horror stories I have read. I don't know what held you back from beating that guy with a wrench. I personally wouldn't have put myself in that situation. That's a tough hard lesson to learn. I wish you the cheapest and best of luck my friend. I would put the worst word out there publicly about that place.
    Senior Member Two Rings StevenStarke's Avatar
    Mar 17 2015
    17 AMS Alpha 12 R8, 22 GSXR-1000R
    LI, NY
    WOW. Just wow. I would have ended up in jail
    2017 R8+ AMS Alpha 12 TT
    2015 GTR - sold
    2013 S4 6mt - sold
    2010 S4 6mt - sold
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Ouch
    Sent from my SM-G928V using Tapatalk
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Veteran Member Four Rings theedge111's Avatar
    Apr 15 2009
    Calgary
    Holy fuck
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    They better be bending over to make this right! Sorry!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Established Member Two Rings H60mguy's Avatar
    Sep 03 2014
    MS3 Track Car
    Tennessee
    Quote Originally Posted by StevenStarke View Post
    Same here. Wow. I'm speechless.
    Sent from hell
    Dec 22 2012
    PHX
    That sucks. Sorry man.
    '11 S4 Prestige | 6MT | Sports Diff | ADS | Nav | B&O |
    Previous: E46 M
    WRB WRX
    Nov 23 2014
    North Carolina
    did the manager say they were going to take care of it after being confronted or is he saying GFY? I've seen a lot of these, but this is by far the worst. Stories like these are what scared me from going to generic places again.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Jan 12 2013
    Jupiter, Florida
    That is terrible, that shop is full of clowns. Good luck.
    Qwik Rick
    2017 Audi Q7 w/APR DP tune, RocEuro,
    Sold
    2010 S4 w/Revo Stage 1+ tune & USP intake, cold front, lw crank pulley, JHM rotors
    12.44 @ 113.56 @ PBIR 1/4 (stage 1)
    12.203 @ 114.28 PBIR 1/4 (stage 1+) 13 Jan 2016
    Jul 10 2015
    SATX
    From all of your contributions and knowledge on the chipwerke front and other topics, I am suprised this happend to you of all people. I'm sorry to hear this happened but thank yoy for sharing, as I am sure your story will save others future heartache such as this. I'm rooting for you and your car.
    Keep us posted.
    Jul 24 2014
    Norfolk, VA
    Oh man that's awful. Hope it all gets sorted for you. If I were you I would contact my insurance company and the corporate office of the oil shop.
    Cheers,
    NM
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Didn't peg you as the type that will go to an instant oil place... Sucks to hear man. Good thing you caught on to their bs quickly.. Car should be fine. I'd get the dsg fluid and engine oil changed at the dealer to be safe
    Apr 19 2014
    Long Island
    Wow. Speechless.
    Please keep us updated. We all want a positive results for you
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    I would have been **** a few bricks. I think this is the best of the best when it comes to knowledge is power and miser all in one... I an so glad you were on top of this, if not it would have been much worse. You know that there was the thing (it's to good too be true) playing a part in this but good for you to see this in the now!
    To cut someone's underbody from their car is un heard of and I commend you for catching this at the time it happened, now days this is the only way. I wish I could trust the quick lube types but the truth is they don't care. I had the shop rotate the tires and after they Cranked it down I couldn't remove the tire, they over torched the tires and I broke every type of wrench (half " and OEM) I had and ended up selling the truck before I had to service it again.
    I live by if you won't do it know one will...
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    I would of gotten arrested... REAL SHIT!
    Jul 21 2004
    South Florida
    Thanks guys. I know how stupid it was not to do the work myself too.
    I will say that luckily one of the police officers was extremely nice. He went over and talked to the tech and came back and tells me that he got a full confession. I was able to get them to at least confess to "cracking" the DSG fluid plug although they wont admit they drained it. No big deal since they admitted to opening it. They also admitted to damaging the aero pan. We'll see if the owner covers the bill. If not, looks like i'll be seeing what the limits are in FL for small claims court.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    What the fuck
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Holly Crap! What a wake up call, thanks for posting and I hope you can resolve this without the courts getting involved.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    This should be an independent shop with the Valvoline franchise name. I would contact Valvoline and address the issue with them as well and have your police report available. Try this as well just as others have had issues with certain Audi dealerships and address the issue with AofA.
    I would definitely let your service tech know everything and make sure they are going through everything with a fine tooth comb.
    Good luck with the vehicle.
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Senior Member Two Rings DirtyDog--IRL's Avatar
    Mar 31 2015
    Columbus, Ohio
    Wow that's insane good for you for standing your ground and getting the cops - hope it all works out
    Apr 11 2012
    damn, that's some BS. I wonder how many cars this guy butchered before he finally got caught.
    Apr 19 2014
    Long Island
    Quote Originally Posted by bhvrdr View Post
    Mike
    Limit in FL is 5k
    Senior Member Three Rings madman4you's Avatar
    Oct 13 2009
    07 GSX-R 750
    Ontario
    Unreal! Sorry to hear. I'm not that old, but feel old these days. I am 31 and I feel like most of those shops have a lot young people working their that feel intitled or just don't give two sh$@ about quality work/customer service. Sadly this is the day an age we live in. I am sure you guys see this all the time in retail also. No one cares.
    It's a hard lesson to learn, but glad you were able to investigate and gather your findings before you left.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    WOW.
    This takes a special kind of stupid.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 20 2008
    2012 S4, 2003 Passat
    Sacramento, CA
    OMG.... in my head I've tried to understand how $13 - $22/hr techs could possibly be trained well enough to remove belly pans without damaging them on so many different types of cars, as well as correctly locate drain plugs & not lose fasteners.... I guess they can't.
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    That totally sucks! What kind of mechanic cuts the belly pan when there are clearly visible screws to loosen it for removal? I've had bad luck with these places when I go to Florida and learnt never go to quick oil change shops. My last Passat they just threw the belly pan away. Didn't notice it till I got back home for another oil change...
    Hope everything works out and they pay.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Wtf thats one of the most rediculous oil change stories I have ever heard. Its a good lesson to learn to not anyone touch your car. I just bought all the tools nessesary to do my own oil changes.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Apr 15 2009
    Calgary
    Mike
    If the fastener hadn't been laying there would you have driven off or were you already planning on going under the car before leaving?
    I'm just blown away by this!
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    There would be an incredible lawsuit going down.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by dave96gt View Post
    Thousands of people have their oil changed by places like this ever day. I'm sure missing fasteners are common, but nothing like this.
    What the hell was the guy even thinking? Was he on drugs? Not sure how one can fail to realize the engine oil drain is located on the ENGINE... The cutting is just beyond comprehension.
    -Hayden
    Jul 21 2004
    South Florida
    Quote Originally Posted by theedge111 View Post
    You know, thats a good question...only because yes I was definitely planning on just pulling the car forward and going under the car because there were so many clues that something had gone wrong from the guys talking back and forth about the engine oil overflowing to me looking down under the car while the front belly pan was finally taken off and seeing the guy taking out a 1/4 turn fastener from under the car AFTER the belly pan was removed (he likely ripped off the front pan leaving the 1/4 turn fastener still in place. But I think about what would have happened if they had not left so many clues behind... if I had driven away and the engine and tranny failed next week or whatever i'd be screwed.
    It was dumb bringing it there. Its one of those things where I am busy busy in the middle of showing our house for sale, closing on a new home, overseeing some renovations on a rental property, and saw the groupon that was cheaper than buying the oil and doing it myself and thought, screw it, why not get an extra oil change if its only 50 bucks? Damn.
    Mike
    2018 Audi S5
    Gone-
    Apr 15 2009
    Calgary
    ^ you can't beat yourself up...it's an oil change, it's what these guys do!
    It's just great you knew enough to check it out and then also found the pieces in the trash.
    Apr 27 2014
    United States
    If you post the exact shop we could post reviews so no one ever had to go through the same thing.
    435I 6MT - Daily
    Apr 04 2012
    MSP
    I'd have fucking flipped! You need to reach out to your local Fox channel and give them this as a story - no one will ever fucking go there again... Wow -
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    That is terrible. And people always ask me why i bring it to the dealer for on oil change. rather than groupon, might as well just wait till audi sends you the oil change coupon in the mail and just pay the extra for the oil. heck my SA just always applies the coupon price + oil for me when i want a change. only cost like $90
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Deactivated Three Rings
    Aug 24 2015
    I'm speechless
    Sent from my iPad using Tap,Tap,Tapatalk
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    You're lucky. This happened near me. It was a new Saab with ~10k miles. It seized a few blocks away.
    Nov 18 2014
    Jersey
    poor decisions yield poor results.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
