2001.5 Built Motor F21 E85 Brilliant Black S4 Saloon
For sale is a 2001.5 Audi S4. Brilliant Black in color. Sport trim interior. 143k on the body. This car was owned by rtl5009 and the engine rebuild, turbos, etc. was done by him. I purchased this car from him back in the summer of this year. Initially I bought this to simply DD on my days off and toy around with. I just want something a little newer for a winter DD and not so race carish lol. It's a really well put together car. All engine mods, turbos, fueling, etc. has 13k miles on it. Here it goes:
Motor:
Done at 130k
RPM Rods
Stock Pistons
Re-ringed and honed
ARP Main Studs
Balanced crank
New main bearings and rod bearings
New head gaskets
New front/rear main seals
Stock heads
New head bolts
New OEM Timing Belt
New OEM TB Tensioner
New TB Roller
New Water Pump
New Acc. Belt
New Starter
New Alternator
New Radiator
Turbos:
Frankenturbo F21 installed at 130k
034 RS4 replica inlets
SRM custom big plenum intake manifold
SRM Intercoolers
Real SAMCO hoses
Stratmosphere DVs
RS4 Throttle Body
3 BAR MAP Sensor
Induktion Oil Feed Lines
034 85mm MAF housing and hose
Stock Air Box w/ Darintake Mod
ITG Lifetime Filter
Braided Waste Gate Lines
Ceramic Coated Stock Manifolds
Ceramic Coated Hot Sides (F21's)
Fueling:
Black 034 Fuel Rails
Bosch 044 FP In tank
Bosch EV14 1000cc injectors (brand new)
4 BAR FPR
10ga in-tank wiring
Drivetrain:
Southbend Stage 3 Daily Clutch and PP
034 Metal Throwout Bearing
Apikol Rear Diff. Mount (blue)
Metal slave and braided line
RS4 Motor Mounts
AWE DTS
Tuning:
Daz Tunes via Boosted Euro (in process)
E85 tune w/ antilag and no lift shift
93 octane tune
Flashloader for easy switching
Other:
Porsche 993TT BBK on Front. ECS hangars
Slotted Rotors (new)
Hawk Super Street pads
Rear brakes new Rotors and pads (stock)
ECodes with new ballasts
Innovate Wideband O2 integrated to OBD2 (new sensor)
AWE Vent Boost Gauge
ST Coilovers
AWE catless DPs (have catted pipes too)
Custom Fast Intentions Stage 2 Catback (new)
Tires are like new on gold plastidipped OEM wheels
Modded fog relay (yellow bulbs)
10mm and 15mm spacers
Custom sound system
RS4 grille
35% tints all around
ICM delete and Coil pack upgrade
I'm sure I missed somethings.
Car runs excellent and I couldn't be happier with it. It's super low key until you start it up. Car is a sleeper. Ran sub 3 FATs before these new tunes. Curious to see what it does when finished dialing in.
I put a lot of money in this car since purchasing it from Rob.
Asking 12.5k. Have CLEAN title in hand.
Will also consider trades:
2.0T A4
B6 or B7 S4
WRX/STI
EVO
Etc.
It's a 16yo car so it has its blemishes. I've cleaned and shaved the alacantara and pinned up the sagging headliner. The paint is in great shape, just some chips up front and few scratches here or there. No rust!
7245702503
List Date: 12/13/2015
For more info, click here to view the original listing: 2001.5 Built Motor F21 E85 Brilliant Black S4 Saloon
This item is no longer available.
