Results 1 to 21 of 21
    Oct 30 2012
    Arizona
    DIY Euro Headlights
    So I refuse to pay in upwards of $1400+ for EURO lights....that is money that could be spent on the engine or suspension etc.
    I bought this used headlight off of EBAY with the intension of doing surgery on it to see how it was put together. It's glued and double sided taped (DSST)like you wouldn't believe.
    This isn't for the faint of heart or people that don't normally do this type of mod...I've been inside several headlight and corner lights over the years doing this same exact thing.
    I first tried to just cut and separate the two housing sections that were bonded together, but there is so much epoxy and DSST it wasn't worth it. The next option is to try open up the side and just remove the amber without too much collateral damage...again..it worked, but too much debris was now inside the headlight housing. I blew most of it out with a compressor, but some remained so I proceeded to cut off the entire headlight lens. It is the ONLY real way to get all of the debris out of the lens, remember..this is a used lens so I didn't really care if I messed it up...the mission here is to see if it's possible to get inside and make this mod happen. The last step: what to do with the amber lens and the 3 LEDs behind it? You could unplug it and let it be or use some metallic spray paint to cover the amber section and reinstall. Finally, use some windshield epoxy to bond the 2 pieces back together and you're done. I would suggest finding some used headlights on eBay for cheap and try one to see if you can do it before "possibly ruining" your vehicles headlights.
    Established Member Two Rings CbutterK's Avatar
    Feb 26 2015
    16 M3, 13 CC R-Line, 03 911 X51, 15 Tiguan R-line, 93 S13, 08 Durango LTD Hemi
    AZ
    Yup. Def not for the faint of heart, or pregnant women, or kids with asthma, etc...
    But for a pro like you, end result is def worth it!!!! Now you have extra $1500 towards stage 3 turbo kit!!!!
    13 Audi TT-RS Stg2+(sold), 15 Audi S3 Stg1+(sold), 11 Audi TTS Stg2+(sold), 11 VW CC stg1(sold), 08 TT Audi 3.2 Cab(sold), 08 Audi A4 SE(sold), 03 996 Cab VF Suprecharged(sold), and too many others to remember...
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Good job man. So what is the deal with the vagcom coding. Do you need to code out the ambers to avoid a bulb out error?
    -cW
    Sent from my SM-G900V using Tapatalk
    2023 X3 M40i Alpine White
    Oct 30 2012
    Arizona
    -cW
    I'm not sure..maybe some else can chime in and see if that can be done...otherwise you will have the light underneath shining through the amber lens and the silver paint...would look odd. Plus....I don't think the Euro's have lights in the side where the ambers are either.
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    Quote Originally Posted by A20V200 View Post
    Can you provide more details as to how you cut off the lens? Any extra info or larger photos could be super helpful.
    If you paint both sides of the amber reflector piece and then line the inside with something like foil no light should get through. That could work while we wait for someone to figure out to disable those lights in VCDS.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
    Senior Member Two Rings JohnnyUtah787's Avatar
    Oct 03 2015
    Illinois
    nice work
    2015 Audi S3 - Glacier White, 19" Performance Package, B&O Sound System, LED Lighting Package, Black Optics grille, Black optics fog grilles, Black powder coated OEM exhuast tips, Satin black 19x8 ET45 Neuspeed RSe10 wheels with Continental ContiSportContact 5P tires (summer set-up), OEM 19x8 ET49 double 5-spoke wheels with Pirelli Winter Sottozero 3 tires (winter set-up), 15 mm ECS spacers all around, Emanuelle Design springs, 034 Motorsport dogbone mount insert
    Oct 30 2012
    Arizona
    Thx. I will get some more pics up. On top of the headlight you want to cut as far back as possible where the lens and housing come together. On the bottom you want to cut just in front of the clips that hold the headlight in....as far as the side cuts, just make sure you join up your top and bottom cuts for one nice uniform cut....make sure the cut on the side with the reflector is as far back of a cut as possible..the reflector is epoxied to the lens and housing.
    San Francisco, CA
    What tool did you use to do the cutting?
    2019 GT3 Touring
    IG: brandongray
    Oct 30 2012
    Arizona
    Quote Originally Posted by phillyquattro View Post
    A cut off wheel in my Ryobi drill..normally used for air tools, but worked great in the drill and I could modulate the speed better. You can see it in the background in some of the photos
    Drill w/ cut off wheel
    Pliers
    Flathead screwdriver
    Windshield Epoxy
    Silver Metallic Spray Paint
    Air compressor or canned air will work too
    Senior Member Two Rings gaogi's Avatar
    May 08 2005
    2008 S4 Avant 6MT
    Irvine, CA
    Back in the B6 and B7 days, I was able to heat up the adhesive by putting the headlight in the oven at 200F or use a heat gun, enough to soften the glue and separate the housing. Is this not possible with our platform?
    2024 Glacier White RS3
    B6 ('02) -> C6 ('06) -> B7 ('08) -> MK6 ('11) -> 8V ('15) -> 8Y ('24)
    Oct 30 2012
    Arizona
    Quote Originally Posted by gaogi View Post
    Yep..BTDT on many housings....this is "unlike" any other one that I've done. Tried the Oven at 275 for 8 then 10 then 12 minutes and only ended up with a very soft back housing that was just getting torn up and the butal glue was till very much in place and was not going to budge. The back half of the housing is a C channel and the lens fits into the C channel very tightly with glue/butal with "Hulk-like strength." That is why a went the other route.
    Senior Member Three Rings DarkSideGTI's Avatar
    Feb 05 2008
    SL,UT
    I would recommend using something else to cut the lens off the housing. Something that will make a much slimmer cut like a razor saw used for plastic models.
    2017 Avalanche Raptor
    2015 Monsoon Grey S3
    Jun 08 2012
    N Massapequa, NY, USA
    Dremel tools (cutting wheels) are pretty thin.
    Established Member Two Rings R3_TDI's Avatar
    Feb 04 2015
    Wiesbaden
    Wow that is crazy..... Just for a amber delete?? This would scare me way too much to even try this on my car
    Sent from my SM-G928F using Tapatalk
    Aug 06 2012
    san diego
    If anyone wants a pair of LED housings in excellent codition i have some on ebay for 600 with a couple bids so far and a buy it now of 800
    Im only selling because i upgraded to the e codes
    http://m.ebay.com/itm/2015-Audi-A3-S...979?nav=SEARCH
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    I would love to have the EU lights but i agree on the pricing, but I dont think I have the balls to try this mod lol
    16 S3 with awe exhaust, usp downpipe, JB4
    2000 911 C2
    Sold 02 S4 with Apr stage 1 / millitek catback
    Sold-07 S4 with DTM kit, JHM tune, stasis exhaust, 19" VMR 710,
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    If you peruse ebay.de you can find ecodes for around $200-250 per headlight.
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by markn1689 View Post
    do you want to remove the oranges before you sell them?
    caveat: only if your in orange county. if your in San diego, ill have to rescind my offer.
    hit me up and ill come over to help you remove them at your place.
    Nov 24 2019
    South Florida
    So I am thinking of doing this and painting all the silver inside black
    Aug 02 2019
    Midwest
    For the lights that are under the now removed amber reflector plastic, just get chrome coated bulbs. They're chrome when now in use and match the headlight housing, and they light up orange when in use.
    This is an example of one. I'm not sure what size the headlights take, but don't remove the bulbs or put aluminum foil in there, lol.
    http://www.matrixracing.com/p-13541-...me-coated.aspx
    B7 RS4
    B6 S4
    May 10 2015
    Pittsburgh PA
    I did this a while back on my B8.5 A4, I just heated up and reused the old adhesive that was on the lights and it sealed back up perfectly. As for the LEDs, I simply coded them out with carista, if you don't they will still illuminate which is a little unsightly.
    Not as scary to do as it looks, just use a heat gun instead of the oven bake method, and take your time, and if you have trim removal tools those help with prying the lens off
    S-Line converted | A7 356mm BBK | OEM 19x9" A8 wheels | Spec Stage 3+ Clutch | ECS LWFW | IE 3" downpipe | CTS catback | IEStage2+JB4 Stack Tuned | Meth Injection and more... +
