Up for sale is a used, but in great working order Stoptech BBK Kit with BLACK Calipers, new retail is $2495 which includes:
- Front Calipers (ST-40) with appropriate brackets
- Front Rotors (332mm). Thickness ~31.5mm
- Rear Rotors, thickness ~10.5mm
- Front stainless brake lines
- Front stoptech street pads
This kit is ready to bolt on using your existing rear calipers, brake lines and pads, however:
PLEASE READ THE FOLLOWING:
- Front pads are low and you'll need to replace them soon
- One of the front rotors has a vibration issue due to pad deposition. I've already re-bedded the brakes in the past and this has helped, but has returned and according to Stoptech the next steps are: 1) Re-bed again and/or 2) Re-bed with Hawk race pads to basically wear off the high spots and then replace with the standard pads. Worst case, you may be in for a new rotor if this doesn't work. Just want to be totally clear!
Otherwise the calipers have no leaks, pistons extend / retract fine and all was working fine when I pulled the kit off my car. Fits all B5 A4 (1996 - 2001 Audi A4)
Shipping is only estimated and can change, all this weighs over 80lbs so would have to be split into two boxes for USPS.
Email serious inquiries to goinggreendetailing at gmail.com
It's on ebay! Here is the link with pictures:
http://www.ebay.com/itm/Stoptech-BBK...FWIn7W&vxp=mtr
