Results 1 to 9 of 9
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Question Finding a replacement 4.2 with good cylinder walls
    were do people find good 4.2's??? i know car-part.com and shokan sell them and sometimes on the classified section theres a decent engine kicking around but otherwise i think they're hard to come by. i looked at a 4.2 long block today that was pulled from car that had timing failure. i scoped it myself and found scoring on the walls . my buddies are trying to convince me to do a 2.7tt swap but i like the 4.2 too much to move on. plus i have a b5 avant in my stable so i'd rather not.
    has anyone purchased from car-part or shoken and had issues?? if so how did you resolve it with them? i don't want to spend $1500-2500 on a replacement only to have the same exact issue i already have.
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Slight chance JHM have a few laying around?
    Ball out and grab Slow4s engine...
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    I ordered one off of a car-part listed re-ferb place. It's was fine.. Don't know where you are getting that number though, unless you are looking at short blocks. Plan to spend closer to $4k for a decent block with low-ish miles. It took me a while to find one too.. Like 2 months of calling around and search sites. Check eBay too. Good luck!
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Nov 16 2013
    Lower NH
    Quote Originally Posted by Blackstallion View Post
    i think he sold it too jimmy bones
    Paging Jake!! you guys have any BHF short blocks laying around???
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Sep 22 2009
    Quote Originally Posted by jmcS4 View Post
    Yeah I'm betting he will most likely part the avant out--he already has an s4 that is done top to bottom...
    BTW what happened to your engine?
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    I leave my short block on junk yard without scored cylinders like 4 month ago
    Nov 16 2013
    Lower NH
    well when i purchased it last year it was doing OK, wasn't burning too much oil compared to my first b6 s4 i owned. did a compression test and numbers were also OK but with a few lower than others. i know my valve seals are bad and possibly valve guides. i also put a camera in the cylinders and saw some scoring on a few cylinders but not all. took the car on a few 1K mile road trips and then it was down hill from there. it burns over a quart of oil if i go for a spirited run with friends and blows smoke on hard pulls in high rpm. also blows smoke when i take off from a stop... pretty depressing if i may say so but i love the sounds and torque of the 4.2 otherwise i'd sell for a B5 2.7 but its also a Nogaro and i love the B6 body lines. its the definition of a love/hate relationship
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    I think Sandspeed just pulled his 4.2 and did the 2.7 swap.
    http://www.audizine.com/forum/showth...S4-today/page9
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Quote Originally Posted by A4Maine-iac View Post
    It's not out yet, but could be soon. I'm about to scope it in the next few days to check for scoring. I just want to have all the info I can get when I sell it.
    -Tim
