Results 1 to 17 of 17
    Senior Member Two Rings nemick's Avatar
    Aug 22 2012
    Indianapolis, IN
    REAR subframe bushings
    Does anyone have a good way to check the condition of the rear sub-frame bushings without removing them? I'm chasing some clunking and spending too much money on things that don't fix it.
    Thanks
    Neil M.
    2004 allroad 2.7T TIP
    2001 A4 1.8TQ, TIP
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    What's wrong? Are the bushes getting too big? I recommend removing the bushes and going with a simple flower bed, preferably filled with annuals. Much less overall maintenance, and the annuals will bring some nice color to the rear sub frame.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Aug 22 2012
    Indianapolis, IN
    LOL. Good point. Editing now. I'm a furriner, bear with me.
    Neil M.
    2001 A4 1.8TQ, TIP
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Usually clunks in the back are rear diff mount
    Aug 22 2012
    Indianapolis, IN
    Quote Originally Posted by Davdraco1 View Post
    I already changed the rear diff mount to the ECS version. This actually made the problem worse as it has virtually no compliance. I also replaced the Tip trans mounts while I was at it. I've closely inspected the center driveshaft support, but I can't honestly see, or feel, anything wrong with it. I can't find anything wrong when the car is on the lift, so I'm trying to narrow it down without simply throwing parts at it.
    Neil M.
    2001 A4 1.8TQ, TIP
    Oct 10 2013
    State College PA
    You moved the center drive shaft around and it didn't wiggle or move at all?
    Aug 22 2012
    Indianapolis, IN
    It had about a 1/4 - 3/8" movement, but no rips, tears or other signs of failure. It was also clean and dry.
    Neil M.
    2001 A4 1.8TQ, TIP
    Aug 22 2012
    Indianapolis, IN
    Does the subframe have to be removed to replace the bushings?
    Neil M.
    2001 A4 1.8TQ, TIP
    Jun 30 2008
    Erie, Pennsylvania
    I would say yes, it probably does. You would likely need to press or cut them out.
    Aug 22 2012
    Indianapolis, IN
    I don't like that answer, can you give me a better one, lol.
    I'm chasing a speed/torque specific vibration and it's driving me crazy trying to narrow it down.
    Neil M.
    2001 A4 1.8TQ, TIP
    Dec 10 2013
    Borden, Ontario, Canada
    More like burning+cutting+more burning
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 22 2012
    Indianapolis, IN
    Quote Originally Posted by Bordom View Post
    Bugger that then. Not worth the hassle until I'm positive it's the bushings that are the real problem.
    Neil M.
    2001 A4 1.8TQ, TIP
    Dec 10 2013
    I have the 034 billet rear subframe bushings, it noticeably firms up the rear, which was surprising
    IG: 24_et
    Sold:
    RIP:
    Oct 10 2013
    State College PA
    Can you replace them with the subframe still in the car? What's the install on those like?
    Dec 10 2013
    I got the subframe like that lol. Just dropping the rear subframe and disconnecting all associated components took me the better part of 2 days with a lift.
    As it was described to me, you burn out the old bushing then cut/hack the rest of it out. Giant PITA apparently. Just lining up the subframe took the better part of an hr
    IG: 24_et
    Sold:
    RIP:
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    I have a vibration that sounds identical to yours. I believe mine is a loose rear axle flange as I can move it in/out about a quarter inch with the rear of the car lifted.
    So you might want to check that although I've never heard anyone else mention it as a common thing.
    Aug 22 2012
    Indianapolis, IN
    Quote Originally Posted by bmos View Post
    I'll be sure to check the flanges then. I'm looking onto a possible cv joint failing too.
    Neil M.
    2001 A4 1.8TQ, TIP
