Results 1 to 2 of 2
    Dec 13 2015
    B7 A4 Build Questions
    I recently upgrade from my B6 1.8t Avant to a B7 2.0t Avant and I've decided I I want to go past the normal stage 1 tunes/upgrades. What I'm looking for is help with my the build path on what components need to be upgraded, things I should consider and watch out for. My main goal out of this build would be anywhere around 350-450hp safe daily. There are a few small modifications I've already made to the car since purchase (3" Turbo back CTS Turbo Exhaust, Southbend stage 2 Daily clutch w/ single mass flywheel, Forge DV, Stage 1 APR). Also I'm pretty new to Audizine so I wasn't sure if this is the right place to post this, thanks for reading and all your guys' help in advance :)
    Mar 24 2013
    Oakdale, CT
    The only thing that should be considered mandatory as far as engine upgrades would be rods. A balance shaft delete and fluidampr would probably be a good idea also. If you don't want to piece your turbo kit together, JHM has their stage 3 kit that will get you where you want to be. It also includes tuning. As far as supporting mods, you'll need S3 injectors, and upgraded PRV, and and upgraded HPFP.
    -Adam
