Results 1 to 40 of 42
Thread: RS5 Brakes
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    RS5 Brakes
    Has anyone fitted RS5 brakes to their S4?
    I'm looking at a full set which includes the 8 pot fronts, wavey discs front and rear, rear calipers, 2 sets of pads, dust shields and pipes.
    Will they be much of an upgrade from the standard brakes?
    Will I need to upgrade anything else i.e mastercylinder or anything?
    Is there anything else i need to consider?
    Ryan
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Here, take look at ECS Tuning site. https://www.ecstuning.com/Audi-B8_S4...rmance/Front/2
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    Why not go with a Brembo/StopTech/etc?
    The Brembo 8 piston isn't that great of a caliper. All of the pistons are the same size which leads to uneven wear, and brake pads are expensive (4 pads per caliper). And the flower rotors aren't very good either (ask other RS5 owners :) ).
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^I don't know about Brembo for cars, but I have loved the reliability of the Stoptech 380mm kit. I had the 355mm on my B7 and liked it as well.
    The pads are a breeze to replace as well. If I do another BB Kit it will not be a Brembo for the car. For the Panigale yes.
    Stoptech is a great set-up and they have my loyalty. I think the AP Racing would be my other choice: http://apradical.stillen.com/
    They look pretty nice and the price is comparable. AP was one time affiliated with Lockheed and they made calipers for aircraft?
    Apr 17 2004
    Socal
    what is your intent for the brake upgrade? Looks or performance? If you're seriously tracking the car I would suggest that you pick up a kit made specifically for the car as any of the big companies (stoptech or brembo) will or should be designing the kit to use the proper caliper and pistons for the vehicle. If it's for looks then whatever floats your boat.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Quote Originally Posted by PsYkHoTiK View Post
    Why does it lead to uneven wear?
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    The RS4/5 system is a good OE upgrade option. I recommend it for people who are looking to do an OE genuine upgrade and mainly are doing this for aggressive street performance and not track use.
    If you are looking for something more track capable there are some great deals on Alcon based systems:
    Brake Package | Revo 370x32mm Front- 25% Off While Supplies Last - Biggest Discount Ever Offered!
    http://www.audizine.com/forum/showth...day-Sale-is-On!
    If anyone has questions on these kits or needs more info don't hesitate to PM or email: contact@europrice.us
    Cheers,
    Jun 05 2009
    Scottsdale Arizona
    ^Alex those are a great OEM upgrade. Probably better to stay with OEM look if you don't track at all.
    Aug 23 2010
    Redmond, WA
    Quote Originally Posted by Pyromatic177 View Post
    Short answer:
    Pad Tapering
    Long answer:
    Properly set up fixed calipers with multiple pistons feature progressive sizing. Typically leading end has smaller pistons with the trailing (rear) end having larger piston. This ensures that pressure is applied consistently on the pad (and helps prevent/reduce pad tapering).
    The RS caliper is an 8 piston fixed caliper with 4 pads per caliper (one pad per pair of brake pistons per side). The 'top' or 'leading' pair will wear out faster since the pistons are all the same size. So instead of rotating pads side to side within a caliper and then switching to the other side, I now have to do a 'cross' swap (lol same pattern as rotating tires) to try and get consistent pad wear - and the way I drive on the track, I do it during lunch time. I have a set of race pads sitting somewhere where 4 of the 8 is almost down to the backing plate, and the other 4 still has some material left.
    More reading here (if you don't mind a bit of a marketing pitch):
    http://stoptech.com/technical-suppor...alance-matters
    http://www.wilwood.com/TechTip/TechCaliperTip.aspx
    Quote Originally Posted by Wilwood
    The caliper should be mounted so that the smaller piston end is closest to the rotor entrance, and the larger piston end toward the rotor exit. The larger piston end provides slightly greater clamping force to compensate for pad taper that can occur under extended severe use applications. An improperly mounted caliper (reverse rotation) will cause increased pad taper and reduce overall braking efficiency.
    I have more info about these systems in another forum:
    http://tinyurl.com/outglls
    http://tinyurl.com/hxauxft
    If for whatever reasons it gets removed, PM me and I'll send it to you (just sharing info, not participating in drama).
    I'm of the opinion that if you're going to spend monies upgrading, get something really good. I don't think going to StopTech or Alcons are that much of a material difference (if any at all).
    OEM Plus modding is great, but the '5' forums is littered with RS5 owners who has had to replace the silly 'wave' rotors under warranty - some even repeatedly.
    To echo (and paraphrase) a comment I once saw, "RS5 owners tend to not like the stock brakes, but the S/A owners seem to love upgrading to them". Haha!
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Cheers for the info guys, I don't intend to track my car tbh but it does get a fair bit of fast road use and hope to be at stage 2+ early next year so think the standard brakes may be a bit under powered. I'm looking to upgrade for looks reasons also and would like to upgrade all round which I don't think is an option with the likes of stoptec, ap, brembo etc?
    What are the problems with the wave discs that people have?
    I have the ecs cayenne kit on my B6 which will be coming off just after Christmas before I sell the car. I've been happy with the kit but it won't fit my B8 without special adaptors and the discs could also do with replacing.
    The rs5 kit I've seen is for all 4 corners which I like the idea of, it's an oem upgrade and the price looks fair for a complete solution.
    Established Member Two Rings deadpool7777's Avatar
    Dec 01 2014
    Wife's econobox... Poor man's tool kit...
    Tacoma, WA
    The pistons are not all the same size.
    Aug 23 2010
    Redmond, WA
    Quote Originally Posted by deadpool7777 View Post
    I stand corrected. Thanks!
    https://www.ecstuning.com/Audi-B8_RS...iper/ES349297/
    Uneven pad wear comment stands though.
    Edit: Pic below (after 1 track day - Carbotech RP2 - which wasn't that great on the car, now I'm using XP24s and they work marvelously with the Girodisc 380mm rotors - with rotations :))
    Sent from my Fruit Phone using Tapatalk
    Dec 01 2014
    Tacoma, WA
    Wow! that is some extreme uneven wear. I don't track my car yet, so haven't had that problem. Thanks for the info.
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    The other thing to be aware of in the RS5 front swap is that these are about the physically largest calipers you can choose to swap to so your wheel choices become VERY limited. Having said that now that I have my winter and summer wheel setups all set I am very happy with my RS5 brake upgrade. The only "complaint" I have would be that when cold and wet the first pump on the pedal results in little braking force, the second pump however is as normal.
    032214_2 by QuattroRocket, on Flickr
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by QuattroRocket View Post
    Very nice. What color is that? Powder-coated?
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Sep 01 2004
    Vancouver Canada
    Quote Originally Posted by ptper View Post
    Painted the VHT caliper paint gold
    Thanks
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    I have the RS5 front brakes on my Car, My track pads are very expensive but since I drive the car year round, I need not worry about pooptechs seizing like mine did on my B5. I have 9 events on the rotors and they are tired 8 before signs of being tired. I run Pagid RS29s which might help with rotor wear. One thing I did that helped a lot on the B8 swap the RS5 Brake Booster and Master into car. Makes the Brake work as they should(no soft pedal). The rear rotors are different offset The hubs are different. If am reading right you are in the UK so you would just use the RS4 rear. Calipers are almost the same minus spots where the RS Beauty plate goes. They are the same size though and use the same pad as the S4/S5. You technically don't need the calipers just the rotors. I think for a dual purpose setup they are great, obviously with some compromises.
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    That is most likely due to the S4 master and booster (same as the A4 sadly) being too small. I noticed a huge difference in pedal feel when I upgraded those parts to RS5 parts.
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Sep 12 2014
    eGolf
    Pasadena, CA
    Quote Originally Posted by littleredwagen View Post
    This is my biggest beef with upgrading calipers. Without a bigger master cylinder the brake feel goes to shyt on these giant calipers. Any OE upgrade I do in the future will be based heavily on the MC's being common or very similar.
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by rlfletch View Post
    Luckily for me the price for the parts wasn't too bad so it was easier to swap the master and booster than sell and by another bbk
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Oct 30 2016
    Boca Raton
    Do you happen to have part numbers for the Brake master and booster? Was it pretty straightforward to install?
    Veteran Member Three Rings rubicant5x's Avatar
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Quote Originally Posted by FlyS4 View Post
    ECS Tuning has the part numbers for both and have the cheapest price (I purchased the wave rotor kit as well, just need to get it installed).
    Links below:
    https://www.ecstuning.com/Audi-B8_RS...der/ES2557277/
    https://www.ecstuning.com/Audi-B8_RS...der/ES2063958/
    Matt
    2018 Audi RS3
    2001 Audi S4
    Oct 30 2016
    Boca Raton
    Damn, almost another grand.I wonder how easy it is to install. Looks like replacing that is the way to go. Pad tapering by underpowering those calipers isn't the route I want to take.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by A4 Centaur View Post
    the stop tech caliper have issues, i would stay far away from what ive seen
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Senior Member Two Rings acsgp's Avatar
    Jul 17 2014
    Singapore
    The one thing that put me off the RS5 brakes is that they're heavier than stock.
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Does anyone know what the maximum size rotor which can be used with the stock callipers (street use only)??
    Need to replace my rotors and pads but want to use something which will work when I upgrade to big calipers
    Jul 26 2014
    You do not necessarily have to replace master cylinder and brake booster. On my S5 I kept them when going RS5 BBK and only swapped the brake lines to ECS stainless steel ones.
    The only downside you may have when keeping OE master cylinder and brake booster is mushy pedal feel or having to put more force on the brake pedal, pad tapering has nothing to do with it. While I cannot vote for the feel with full RS5 system my personal impression of RS5 calipers on otherwise OE braking system is good. SS brake lines may or may not have helped with potential mushy feel issue in my case.
    Pad tapering is in most cases due to wrong pad used for the driving style, bad caliper construction (e.g. same size pistons used in calipers with long brake pads) or lack of caliper maintenance. RS5 8-pot Brembos use 8 pads each (2 pads per each side and not one long pad) and different sized pistons (unlike stated above) so they are fine from pad tapering viewpoint.
    2011 S5 Sportback
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    I ended up going with AP racing setup in the end with 390mm j hooked discs, they performed flawlessly on the 1 track day I've been on so far
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Quote Originally Posted by acsgp View Post
    The caliper might be heavier but I'm pretty sure the two piece scalloped rotor is lighter than the stock S4 rotor.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by RyanJon View Post
    Amazing feedback through the pedal too. A huge upgrade in terms of feel for me.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Oct 30 2016
    Boca Raton
    Quote Originally Posted by -leman- View Post
    Thank you for the reply. I am debating on the SS braided hoses. I have the kit sitting at my office. Will probably do everything at once. I will not like any mushy feel.
    Quote Originally Posted by rubicant5x View Post
    They are lighter. ECS tuning has posted numbers comparing their rotors to RS rotors and their rotors to stock rotors. You can compare the Data and indeed they are on par with any other 2 piece set up out there in weight. Although the weight of the caliper might be more, its sprung and mostly going to affect the suspension response. Good thing the rotor will compensate with less weight which is unsprung so you will still feel performance increase (acceleration).
    Established Member Two Rings s4bw's Avatar
    Sep 14 2010
    MKVII GTI PP,12 SIERRA DURAMAX
    Anmore B.C.
    I have RS5 front brakes with ECS 2-piece rotors. I weighed the kit VS. the stock parts and the RS5's were about 3lbs per corner lighter. Also did the rear ECS 2-piece rotors, they saved about 3LBS each as well.
    BBS CH-R 19x8.5 w/ PSS /H&R OE SPRINGS/AWE EXHAUST W.RESONATED DOWNPIPES ,APR STAGE 2 V3.0, E-codes, EUROCODE TRufit intake. Alu-Kruetz, Apikol diff mount, 034 trans mount, AWE Coldfront,H&R swaybars,CR-15 strut brace
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Quote Originally Posted by s4bw View Post
    You mean the non-Scalloped 380MM/330MM rotors respectively?
    Matt
    2018 Audi RS3
    2001 Audi S4
    Oct 30 2016
    Boca Raton
    I am on the fence either I should sell this whole set up and just go with Girodisc front and back and powdercoated Q5 4 piston Brembos....
    Sep 14 2010
    Anmore B.C.
    Yes, non-scalloped 380/330 ecs 2-piece
    Apr 05 2016
    2001 Audi S4
    Cleveland, OH
    Thanks.
    Matt
    2018 Audi RS3
    2001 Audi S4
    Sep 14 2010
    Anmore B.C.
    Here is a pic of my setup. I run stock 18's in the winter as well. They fit with 10mm spacers
    Oct 30 2016
    Boca Raton
    How fast do these rust?
    Sep 14 2010
    Anmore B.C.
    Do you mean the surface of the rotors? They rust right away after washing the car, like all steel rotors. As soon as you drive the rust comes off.
    Oct 30 2016
    Boca Raton
    Some rust more than others. I have new updated Audi rotors with black hats and comparing to GiroDisk they almost didnt rust after a wash. I wet them equally.
