Results 1 to 3 of 3
    Active Member One Ring Deacon S4's Avatar
    Nov 04 2014
    Everett, WA. USA
    Tiptronic RPMs at 60mph?
    Trying to figure out what the 04 Allroad 2.7T should be turning for revs on the hwy at 60 or 70mph? It seems to me that the OD may not be functioning in the Tiptronic as it seems to be spinning too high. Any thoughts?
    2014 S4 Estoril Blue, Black Optic, Sports Diff, blah, blah, blah
    I have the 2.7 sedan so not sure if the rpms would be different but I checked this morning and at 60 I'm at about 2200 and at 70 I'm just under 2600
    Using Tapatalk
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    im thinking for mine the rpms at 70 are 2800-2900
    60 would be around 2400-2500 im guessing
    when cruising the interstate i set the CC at 3k rpm and that gives a speed of 72-73 and decent mpg
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
