Results 1 to 22 of 22
Thread: Passport Max?
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Question Passport Max?
    Hey guys/gals,
    I have a passport max. It works great but it won't click into its mount. So I decided to put double sided sticky tape and now it mounts. In order to take if off, you must take the whole sticky mount off. I can't stand that.
    ASOLD ----- nyone want it for $250? Box/manual and cable included.
    2019 SQ5, 2021 Q7
    Mar 21 2015
    V1 or nothing
    Feb 17 2008
    Ashland, KY
    The GPS feature is a must for me. Actually I'm planning on getting the Max 360.
    2019 SQ5, 2021 Q7
    Mar 21 2015
    V1 with Yav1 on android device is so much better. Google it. Blows that escort out of the water. Theres more to a radar dector thn you think.
    http://www.rdforum.org/forumdisplay.php?f=159
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    What's wrong with the mount? I'll consider taking it
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Oct 20 2008
    Denver
    V1 or nothing
    please.
    Feb 17 2008
    Ashland, KY
    The little plastic clip on the detector has worn out so the metal part from the suction mount doesn't click in. I just put double sided sticky tape and slid it in. Mounted solid and no vibration.
    Quote Originally Posted by DGVR6 View Post
    2019 SQ5, 2021 Q7
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    V1 or nothing
    I have the V1, although its nice with the arrows, the false alerts on K and X band are annoying. Also it doesn't have a mute button unless you push the knob. I looked online to buy a remote mute button but V1 doesn't seem to make one from what I could find. Just some home brew ebay specials.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Feb 17 2008
    Ashland, KY
    I'm sure the V1 is awesome but having an app and my phone mounted on the dash every time look like a pain in the ass. I like the plug and play of the max (or max360 which is what I'm getting next).
    My experience has been great with the max. It alerts so early that I have never been surprised. Built in GPS all the way!
    2019 SQ5, 2021 Q7
    Mar 21 2015
    Quote Originally Posted by dizzlesizzle View Post
    Custom sweeps my friend. Just download the V1 app and you can set up specific sweeps of each band and get rid of those false alerts in your state. There is more to the V1 then you apparently know. When you set up the sweeps it essentially narrows the sweep and makes your detector sweep the wanted bands faster for a quicker alert. Once you set up the sweeps it codes your V1 and don't have to open the app ever. An update with junk filter and kpop off will help you tremendously with false alerts.
    Find your state and set up your sweeps. It doesn't take much.
    http://www.rdforum.org/wiki/index.ph...aphical_Survey
    Many guys have mounted the knob from the concealed display for muting in various locations. Do some research, there is so much more to it then you think.
    Jan 18 2015
    Remote mounted mute button for v1 using the concealed display.
    Mar 21 2015
    ^ Whats that in the lighter?
    Jan 18 2015
    ^^ Bilstein coilover control switch (B16 ride control).
    Nov 19 2011
    Rhode Island
    I did do my research...the sweeps and custom coding and frequencies can only be done if you have the ESP version of the V1. Unfortunately mine is not the ESP version...and the app will only give me a fancy front end display.
    Mar 21 2015
    ^Time for an upgrade. Once you set it with app you don't have to use the app ever again. Set it and forget it. It's quite simple. You can get a pretty good amount if you sell your version. Mine needed a $90 update so I sold it for 275$.
    Feb 20 2006
    NC
    Does anyone else have the issue with BSM? I sold both my v1 and Max bc they drove me crazy with a false k band.
    Mar 21 2015
    Upgrade the V1 to get rid of the BSM issue. Some say turning pop mode off helped but it didn't in my case. It's perfect now after buying the new one. Hey Scotty, you get anywhere on the free map upgrade yet?
    Feb 20 2006
    NC
    Not yet. But I will be trying more over Christmas break.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    V1 or nothing
    Amen!
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Feb 17 2008
    Ashland, KY
    Clocked over 150 miles with the new Max 360. No regrets. The magnetic mount is amazing! Very few false positive. In all cases, was alerted of police before I could even see them with my naked eyes (flat straight and curvy roads).
    Like I said, Im sure V1 is great but the last thing I want to do is have an extra app on my phone to distract me from the road.
    2019 SQ5, 2021 Q7
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    I prefer the Redline over the V1. I recently sold my redline and replaced it with the new 360 Max. I can't quite tell the performance difference, but it is there. The Redline also blocks guns from signaling the user their signal was intercepted.
    "People who think they know everything are a great annoyance to those of us who do."
    Aug 03 2014
    Queens
    Thanks James
    Good luck with the new 360
    Previous
