    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2001 S4 - 00654 - Seat Belt Tensioner Igniter; Driver Side (N153) 32-00 - Resistance
    Best way to troubleshoot the 32-00 - Resistance Too High code?
    Is there a good DIY how to get to it and remove the tensioner?
    I hate dealing with those plastic covers (and their clips).
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Aug 04 2013
    Pennsylvania
    What does VCDS say the resistance is? I've never really messed with Audi airbag codes but on other makes I've fixed plenty of airbag lights by unplugging the connector and plugging it back in a few times.
    If the resistance is a tenth of an ohm too high, or whatever the tolerance is, it'll turn the light on. Sometimes playing with the connector of the component in question will be enough for it to make better contact and lower the resistance.
    Worth a shot, right?
    Should be able to get to it by removing the pillar trim
    I'm like a tree. I'm all root
    Feb 20 2010
    Brighton, MI
    Similar experience here (N199). When that did not work anymore, I cut out the connector (yellow) and soldered the wires (for the notorious under seat connector, I actually spliced a short section of additional wire in to prevent the 'stretch').
    Pillar trim: sounds easy, but based on past experience (B5 A4, C5 A6, B5 Passat), lots of other plastic needs to be yanked/bend/ and tabs broken.
    Will only attempt if good DIY showing the tabs/clips locations and how to best get them out.
    05 Golf TDI
    Aug 04 2013
    Pennsylvania
    I've never removed the pillar trim so I can't help there. Interior is my least favorite. On the one hand, it's nice to work in a car and stay clean and stuff but I find it so frustrating. Under a car being functional is the most important part but with the interior it needs to look nice and not squeak and rattle and it just tries my patience lol
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by vtraudt View Post
    Bump for good DIY
    Sent from my Nexus 7 using Tapatalk
    05 Golf TDI
