Need some help diagnosing a P0171 lean code.
A few weeks ago I got solid CEL and pulled P0171. Cleared it and thought it was fluke given that i put some injector cleaner in the tank and ran the tank to almost empty on separate occasions. Car drove fairly normally until today.
This morning I started to get bouncing idle. Its normally around 800 but now surges up to 1100 and comes back down to 800 pretty consistently. This is ONLY happening at low RPMs i.e. stopped at a stoplight. Otherwise car behaves normally at higher RPMs, though a little sluggish. No misfire the way a CP failure would feel, but notice some exhaust sputter occasionally. When putting the car in park it was surging up to 2.5K RPM.
Otherwise performance is fine and car is still boosting 16+ on stage 1 tune.
Any thoughts? Faulty MAF? The PCV and most check valves have been replaced recently, and i'm not hearing/seeing a significant vacuum leak.
