Results 1 to 10 of 10
    Veteran Member Three Rings Aok303's Avatar
    Jul 12 2012
    Bicycle bicycle i want to ride my bicycle
    Lakewood-Morrison / Colorado
    Noob asking Rim and wheel question
    19x8.5 et35 will that be flush on a b7 s4 or would i need spacers?
    right now im stock height soon will lower so i dont look like im Hoover above
    Veteran Member Three Rings mark_ma's Avatar
    Feb 25 2015
    Denver/Colorado
    Quote Originally Posted by Aok303 View Post
    cant speak for b7's, but im sure its the same thing as b6
    but for b6's from what i have researched
    yes, a 19x8.5 et35 will be close if not flush with the fenders
    if i am wrong, please correct me!
    Le build thread of mark_ma,
    Instagram: @mark_b6s4, Youtube: markb6s4
    4 wheels, 8 pistons, two mufflers , ultra light weight seat warmers, see through windows, carbon fiber turn signals, wireless key fob, photon reflecting side mirrors
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    ive got ET 25 and had to put 5mm spacers on rear to "flush them up...
    so on your setup, i would imagine you would need spacers, you will just have to try them on
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Established Member Two Rings RedS4avant's Avatar
    Jun 26 2015
    Way out in the sticks, BC
    I I would agree with TarlCabot I have 18x8.5 et35 and looking at 10-15mm in the back and 5mm in the front
    Jun 26 2015
    Also I'm running undersize winters 225/40/18 so it is quite noticeable that I need spacers
    Jul 12 2012
    i have spaces on my stock audi wheels that are 18x8 et 43
    So id probbally need 5 front and test fitmit the rear to liking it looks like
    i was hoping someone has 19x8.5 et35 and could tell me what he did to make it flush
    what actual size do you have in the rear reds4avant the spacers are they flush and are you dropped
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    i ran a 8' wide wheel with an et of 45 all around. in the rear i ran 25mm spacers and 20 up front. yes i rubbed when i was at almost full lock but never in corners. my FTG is 23.75", so its low as low can be
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Three Rings Quadfreak's Avatar
    May 01 2012
    WA
    I have 19.8.5 et35 wheels on my B6 with 235/35/19 tires
    They are not flush on their own. I put 10mm spacers in the rear, that puts it out flush, but I do rub on big dips. 10mm in the front is too much without some serious fender massaging. 5mm in the front would probably do the trick, but I don't have any 5mm spacers to try out. Im running about 25" ground to fender.
    Brilliant Black B6 S4 - JHM Tune | JHM LWFW & Stage 4 Clutch | JHM 6-Rib Kit | JHM IM Spacers | Milltek CB & DPs | JHM Trio & Delrin Knob | Vogtland GT Coilovers | Rotiform MIA | 034 Snub Mount&Bracket | 034 Motor and Tranny Mounts | 034 Rear Sway Bar | 034 Front & Rear Endlinks | Stern Adjustable Control Arms | Apikol Diff. Mount | CF Relak Side Skirts | Maxton Front Lip | 3k HID Fog Lights | Full LED Depo Taillights | Full Sound System
    Jun 26 2015
    No spacers for me yet and stock height
    Veteran Member Three Rings Brettannica's Avatar
    Oct 14 2012
    2010 Audi A4 Avant
    Perth, Western Australia
    I run 19x8.5 et32
    Spot on
    In The Garage: B7 S4: JHM Tune Carbon Fibre: Vis Racing Hood, Relak Skirts & Paddle Extensions, Blades, DTM Deck Lip : 034 Snub & Bracket : JR Air Filter : H&R Springs : F.I. Catback : Gunmetal 19” 6RS V10’s • B8 A4 Avant: BSR Bling : 19” 4RS V10’s : V-Tech Chip
    Previous Rides: • E32 BMW 740i • E36 BMW 325i • B5 A3S • B6 A4 • Ford Falcon 351 • Triumph TR8 • Vauxall Super Tourer • Saab 9-3 • Saab 9-5 • Toyota Prado 4x4
