Results 1 to 9 of 9
    Jul 20 2013
    Bothell WA
    Help!! Stripped wheels lugs, what now?
    I stripped some bolts when trying to swap off my summer wheels to my winter wheel setup. The wheels I am switching to have spacers and I just noticed there are longer bolts for the rear than the fronts (duh). So now this piece is screwed up, what am going to have to do to remedy this since the whole piece on the car seems to be stripped and replaced?
    I tried using fresh bolts but stripped more.
    2019 S5 Sportback Premium Plus - Glacier White Metallic - Black Optics - S Sport Package - B&O - Carbon Inlays - Fina Nappa Leather- Audi Rings - RS Grill Black Optics - Expel full front PPF - 35% matching front window tint- 50% windshield - Verstarkt Stage 2 Tune - Resonator delete - Vossen HF-5 Gloss Black/Continental Extreme Contact DWS06 - 034 Motorsport Tranny Mount
    Oct 09 2008
    That blows. You could try chasing the threads but if that doesn't help I'd replace the hub.
    The Awesome™
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    Quote Originally Posted by Phantom2010 View Post
    use a tap - i have stripped the bolts and the hub on a lot of cars a tap has always worked well, any tire shop will have them
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Oct 02 2006
    Wadsworth,OH
    If a tap doesn't work you'll need to replace the hub as others have said. We have them below.
    Jason
    Veteran Member Three Rings yakev724's Avatar
    Jun 26 2014
    Brooklyn
    You can get the OEM (Febi) wheel hub/bearing assemblies for ~$120 each, just search the part no. online.
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    better get these to avoid it next time
    http://www.tooltopia.com/thexton-500...RnPhoCPuLw_wcB
    but get the ones that fit the Audi
    Steve
    '15 SQ Monsoon
    May 05 2009
    Cupertino
    Quote Originally Posted by Smittylube View Post
    you just blew my mind
    2015 SQ5 :034 Trans Insert, 034 RSB, 034 X-Brace, H&R-1, Photosync front, Xpel front, OptiCoat, Windsea Sunshade, EPL....$$$$$
    SOLD : B8 A4 2.0T Quattro / Huper Optik 50% / Eurocode FMIC /Eurocode USS system/ APR Quad Tip Turboback / APR K04
    Jul 20 2013
    Bothell WA
    I was able to repair the threads with a tap as some of you have suggested, thank goodness!
    It is also good to know there are some other low cost alternatives out there (and that others have done this before), should one need to replace their hub!
    Thanks guys!
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Btw there is a lug stick in your tool box by the spare.
    Easier to to get a few more unless you use a jack and do one wheel at time.
    Also suggest a torque wrench to tighten the lugs when finished, but that's just me and my anal ways.
    If you really want to go all out they have Teflon coated sockets for cheap ( like $8-10) so you don't bugger up the rim.
    Steve
    '15 SQ Monsoon
