Results 1 to 4 of 4
    May 03 2015
    United States
    Unhappy Need help replacing wheel bearing and Hub on rear for my B5 1.8t qttro
    Hey guys anyone available to give me insight if not a helping hand to change out my rear wheel bearings and wheel hubs,my skills aren't so good since returning from the Middle East however fixing cars gives me relaXation away from military service
    Thanks
    Stage 2 Banner Advertiser Four Rings Kai@EliteMS's Avatar
    Mar 22 2011
    Lindenhurst NY - Long Island
    If you don't have a press or proper tools it is not a fun job. Where are you located? Bring it by the shop we can assist in at-least pressing in the bearings if you want to do the rest yourself.
    ELITE MOTORSPORTS
    21 W. SUNRISE HIGHWAY LINDENHURST NY 11757
    www.elitemotorsport.net - www.elitemotorgroupny.com
    P: 631.775.6634
    Follow Us On Facebook
    Follow Us On Instagram #elitemotorsports
    Follow Us On Twitter
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Buying a hub with bearing will be more expensive than getting a bearing pressed in but if you do it all yourself than the new hub with bearing is probably a better option. If not, go to Kai or a trusted shop or PM me. I have a few good trusted mechanics i could refer you to. No phonies.
    Jul 04 2012
    Woodbridge, VA
    There is a wheel bearing press kit from harbor freight. http://m.harborfreight.com/fwd-front...ers-66829.html coupon 83638638 will give you 25 percent off.
    It will allow you to press in the bearing without taking off the spindle/upright, thus no need for realignment of your car.
    You'll also need a bearing separator to pull the hub out of the bearing. http://m.harborfreight.com/large-bea...not%20provided. To do this, simple get the tapered part behind the hub between the hub and spindle, but don't close the separator too hard on it. Then just put your lug nuts in your hub and the separator will act as a backplate to push on. Just tighten each lug nut a bit at a time so you do not pull the hub out at an angle. You might have to flip the separator around so it faces towards the car, can't remember.
    With the hub out, unbolt the top of the spindle, pull it down to remove the axle from the back. Then bolt the spindle back on the top. use the puller to PULL the bearing (believe it needs to go out the direction away from the car. There is a lip that you'll want to pull away from. This lip prevents the bearing from being pressed completely through the spindle. ) once it's out, use the puller to push the new one in. Youll want to put a little grease around the bearing to aid the push. This part of the job will wear you out so I hope you have a long breaker bar or a huge socket wrench. You'll have to use a plate that is just small enough to fit into the spindle without getting jammed but large enough to push on the outer race of the bearing. If you don't you'll end up pushing the insides of the bearing in and damaging the bearing. As long as you get close to the same size as outer race you'll be just fine.
    To put your hub in, just put it as far as possible with your hand. Unbolt spindle to get your axle back in. Put spindle back but do not fully tighten. Put in axle nut and tighten until it is pressed in. But do not fully tighten. Put wheel back on and lower car to ground. Now with it on the ground, tighten axle nut to 90ft lbs plus 180 degrees(half turn). You'll need a breaker bar. Then tighten top of spindle. Reason for waiting is to preload the suspension.
    Make sure you have a new axle nut to put in as these aren't reusable
