Q7 coilovers
High spec coilover kits offer the perfect balance between road comfort and track performance, simply switch between the two by dialing in your preferred damping level from the 30 settings available.
Each kit is made for, and tested on, your vehicle and is fully height adjustable from stock height, to up to 50mm lower.
Our Kits are available with black or white springs and features four performance suspension dampers, SAE-9254 cold-wound steel springs, and a choice of rubber joint mounts, or pillowball mounts (where applicable). All coilover kits are supplied with a 1 year guarantee.
Features:
Monotube dampers with rubber top mounts as standard.
All kits are damping force adjustable with 30 settings to choose from at the turn of a dial.
Coilovers are fully height adjustable and can be adjusted whilst installed to the vehicle.
Springs are constructed from SAE-9254 cold-wound steel and are protected by a high strength surface coating, which is available in black or white.
Customers have the option of choosing our recommended spring rate or their own custom rate.
Rowetechllc.com
https://www.facebook.com/rowetechllc/
List Date: 12/13/2015
For more info, click here to view the original listing: Q7 coilovers
This item is no longer available.
