Results 1 to 4 of 4
    Nov 22 2015
    Acworth, GA
    Car will not move in drive or reverse
    This has me a little stumped, i just finished installing my coilovers, decided to take the car out for a test drive and it will not engage reverse, drive, S, or any of the tiptronic gears. (car is an 07 avant quattro tiptronic). When in reverse or drive i can hear the transmission wirring and if i put it back in park from reverse it will buzz on the parking pawl so i know the trans is spinning but the car will not move. I will say the car spent a day or two tilted on jack stands but i cant imagine that would cause that much of an issue. Prior to all this the car was driving perfect.
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    Did one of your axles come out in the process? That will cause the problems you are experiencing
    Feb 24 2004
    Minneapolis
    When I had those exact symptoms on my B5 Quattro, one of my CV joints was broken. All it takes is one axle spinning freely and all the power goes to that wheel - and you go nowhere. Check all the half shafts and be sure each wheel is tied to its differential.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 22 2015
    Acworth, GA
    That's the problem, right from axle popped out of the front diff, fixed it and car drives great again
