2006 Audi S4 Avant wagon 6-speed manual
For sale is my truly loved Audi S4 Avant wagon. Moro Blue with Silk Nappa black leather. Driven as my daily driver. Everything works 100%. The AC blows nice & cold, the heat is nice & warm, and there are absolutely no electrical issues.
Currently has 130,655 miles
Options:
-Heated front & rear seats
-Factory-installed navigation (with current DVD for roads)
-Factory-installed BlueTooth
-Reverse sensors
-Factory power sunroof
I installed the following modifications/ upgrades:
-OEM European-spec headlights with Phillips/ Osram 5,400K xenon bulbs. The light beam/ pattern that emits from these headlights is far superior to the U.S. DOT specs.
-OEM front black grill w/ S4 badge/ emblem. This gives the car a far more sporty look/ stance.
-Piggie downpipes (~15-20hp gain)
-35% window tint -- all glass except front windshield
-RS4 replica wheels/ rims (18.00 x 8.50") with Michelin Pilot SuperSport tires
-Also included are the OEM BBS rims (18.00" x 8.00")
Highly maintained:
-New clutch & flywheel (RS4 clutch and OEM updated flywheel) (changed @102,000 miles)
-New master & slave cylinders for clutch (OEM) (changed @ 102,000 miles)
-New control arms & swaybar links (all OEM parts)
-New outer tie rod ends (OEM)
-DBA slotted disc brakes & Hawk HPS brake pads -- both front & rear (approximately 30,000 on these)
-New water pump (changed at 110,000 miles
-New OEM alternator & all related pulleys/ tensioners, & belt (changed @ 110,000 miles)
-New valve cover gaskets & cam seals (changed @ 110,000 miles)
-New fuel filter (changed @ 110,000 miles)
-New oil cool seals & oil filter flange seals (changed @ 110,000 miles)
--New front wheel bearings (changed @ 115,000 miles)
-New inner & outer CV boots (changed @ 122,000 miles)
-Transmission fluid flush (changed at 115,000 miles)
-Rear differential fluid flush (changed at 102,000 miles)
-Power steering & coolant flush (changed at 110,000 miles)
-Spark plugs changed @ 100,000 miles
-Battery replaced 3 years ago and is OEM
-Oil & air filters changed at proper intervals
Disclosure of body:
100% original factory paint.
Front & rear bumpers are 100% free of scratches/ scuffs/ dings.
There's 1 minor door ding on the rear passenger-side door.
This Avant is 100% accident-free and has a clean title and CarFax report.
$17,500.00 or best offer. Serious inquiries ONLY.
https://detroit.craigslist.org/okl/cto/5357116202.html
