Results 1 to 9 of 9
    Senior Member Two Rings McFuzz's Avatar
    Jun 20 2014
    CA Bay Area
    Dashcam and hardwiring to a constant 12v source
    Howdy!
    Those of you who have their dashcam hardwired into a constant 12v source (i.e. one that remains on EVEN when ignition is off), have you had any battery drainage issues if you, say, parked it for a day or two?
    Active Member Two Rings IngolstadtTech's Avatar
    Nov 05 2015
    1986 Ford Mustang Lx Notch
    Massachusetts
    I would have to ask what the draw spec in the camera is. Maybe for a day or two you might not have an issue, but it would def bring the battery amperage draw above spec. Out of curiosity, why would you want to hard wire a dash cam? For when the car is parked?
    Jun 20 2014
    CA Bay Area
    Quote Originally Posted by IngolstadtTech View Post
    Correct - for when it is parked not at home. That said - it'd never be parked outside my garage for more than a few hours at a time. However, if it has to go in for dealer service, I'd like to have the camera up and running and record everything that happens while it is being 'serviced'; I may not be able to pick it up the same day so that's the reasoning for my question.
    Nov 05 2015
    Massachusetts
    I personally unplug dash cams in cars while I am working on them. I feel like if you can't trust me to work on your Audi, you need to find someone you can trust, plus, I dont like being watched while i work. (end opinionated rant lol)
    That being said, with a quick google search, it seems like these cameras draw anywhere between a half an amp to 2 amps. The lower the amperage the better but I think you'll be more than ok for a day or two. They also make hardwire dash cams with motion sensors to conserve power. I would def put some kind of switch in though so its not always drawing that power or you will find yourself with a dead battery
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Hardwire it through a power magic pro so you can cut off power to the camera if the battery voltage gets too low.
    Sent from my iPhone 6s+ using Tapatalk
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Jun 20 2014
    CA Bay Area
    Quote Originally Posted by booost View Post
    I'm guessing the wiring procedure is identical regardless of whether you wiring the camera directly or using one of these battery minders?
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Quote Originally Posted by McFuzz View Post
    They have constant power, switched power, and ground; the dash cam's 12V plug connects to the Power Magic Pro and it works through that. You can set the voltage to choose at which point the dash cam turns off to preserve battery life. I strongly second the suggestion to use one of these.
    Sent from my iPhone 6 using Tapatalk
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings Smellie's Avatar
    Apr 21 2015
    1996 Supercharged Miata
    Penn State University / LI,NY
    Damn.. I was hoping there was some kind of handheld rechargable battery pack that can power a 12v
    2012 B8 A4 | CTS K04/APR 100 oct K04 Tune | 329whp/348wtq | 12.35 @ 110
    AWE "Track" Exhaust | CTS Turbo Downpipe | CTS Test Pipe
    ECS Kohlefaser Intake | Treadstone TR11 FMIC | Snow Performance Stg. 2 Water/Meth
    VMR VB3 19x10 | Airlift Performance 3P
    Oct 20 2008
    Denver
    hardwired power magic pro for my blackvue dr650, set to stop recording if the batt drops below 11.8V. i've gone a week straight (recording while parked) and it didn't drop below 12v at all.
