Results 1 to 30 of 30
Thread: ESP in a4s?
    Established Member Two Rings cclarkb5's Avatar
    Feb 02 2015
    1991 Audi 90 20v
    Bellingham, Washington
    ESP in a4s?
    Do we have ESP in quattro b5s? Or is that just a FWD thing and an s4 thing? I assume there would be a light on the dash with a squiggly car. With that in mind do we have any form of traction control at all? Can't find a thread where people know for sure.
    They last long if you treat them any better than totally shitty. | 1999.5 2.8QA Volcano Black Mica | 1991 90 20vQM Pearl White |
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Definitely don't have it in my B5 A4 5 speed. My dads 06 auto does in fact have it though. But that's not a B5.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Nov 03 2011
    All Over!
    My 2000 B5 2.5 TDI V6 Quattro doesn't have ESP.
    My 2000 B5 2.8 30V V6 Quattro does have ESP.
    1986 Type 85 Audi 90 quattro
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    ESP was included in the Bosch 5.3 ABS Module which was an option for some years. Standard cars have the Bosch 5.0 module which has EDL (Audi's name for traction control).
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    It was an option which was quite rare to find.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Nov 03 2011
    All Over!
    It must be different with North American models then. Because European B5 facelift (1999 - 2001) 30V Quattro are VERY common with ESP. It's actually more difficult to find these models WITHOUT ESP.
    Feb 27 2011
    Winnipeg
    My 2001 S4 tiptronic has ESP however my brothers fully loaded 01.5 2.8A4 5mt does not have it, I've only ever seen auto trans cars with ESP here in Canada.
    May 10 2015
    Pittsburgh PA
    ESP was standard on the S4 and all FrontTrak B5s, The Quattro models were equipped only with EDL which stands for "Electronic Differential Lock" a system that uses the brakes to help lock up the center diff. This is what I read in my owner's manual a little while back. This is for North American Spec cars, according to Nollywood the Eurospec models received ESP with Quattro.
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    They're out there. Only ever seen them in 01 b5's but even then it's a rare option I think
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Quote Originally Posted by 19birel View Post
    Maybe auto FWD, because mine definitely only has ABS.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    May 10 2015
    Pittsburgh PA
    Quote Originally Posted by Wrath And Tears View Post
    Maybe it was standard for just the facelift models, I have a 99.5 so that's the owner's manual I read from.
    Nov 03 2011
    All Over!
    EDL-equipped B5's don't actually show it's fitted. It has no dash warning lamp, as it simply works quietly in the background.
    My 1995 B5 2.6 Quattro had EDL.
    Apr 03 2014
    17 GTI Sport
    That would make sense. Pretty sure it was an option for my car that the guy who purchased the car did not get. I often wish I had it when it rains and I stop a little too close to the painted line. I usually spin my tires on them when its wet enough.
    Nov 07 2010
    South of Heaven
    My 2000 1.8T Canadian Spec quattro has an ESP light in the cluster that comes on with the ignition and goes out when it is started so I would imagine it has it.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    wait so whats this Ecl or eps thing on my daily b5s dash? 2001.5? never lights up other then initial start...
    Nov 07 2010
    South of Heaven
    Quote Originally Posted by Tanzimur View Post
    ESP is used on DBW cars to modulate the brakes/throttle to stop wheel spin when it occurs. I don't feel it much in the dry but there are a few places where I have it kick in on full boost on wet sections of road where the suspension starts to unload. My car is a 2000 but it runs the engine management from a 2001 and the ESP still works. It kicks in pretty hard most of the time and always catches me off guard.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    Jun 30 2008
    Erie, Pennsylvania
    ESP does much more than stop wheel spin, actually. It has a yaw rate sensor (accelerometer package) and a steering angle sensor. Using those sensors along with vehicle speed, the ESP module knows how much turning G-Force to expect when you turn the wheel a certain amount, for instance.
    So you hit a snowy corner at 20mph and turn the steering wheel 90 degrees to the right. The ESP watches the yaw rate sensor to see if the appropriate amount of turning G-Force happens. Obviously it doesn't because you have bald all-seasons and just took that turn WAY too fast. Your A4 is understeering like that's its JOB. You are careening toward certain death due to your careless driving. Nice work.
    *Enter ESP*
    ESP kicks in (yo!) to save your butt from going in the ditch (and dying). It quickly recognizes that [you are stupid and] you are blowing the turn and promptly applies the brakes to the INSIDE RIGHT wheel. This has the effect of turning your car like a TANK. You know...with the treads? Anyway, ESP is pretty awesome in this respect. It works to keep the car headed on the requested turning angle, even when the front tires lose grip. It also works in the opposite mode to kill oversteer. It will apply the brakes to individual front wheels in order to keep the back end behind you...where it belongs. In addition to applying the brakes, it will also adjust engine output power as necessary in order to keep the car on course. The important part is that ESP does things that you actually can't do. It can apply the brakes to a single wheel to make the car do something special. You only have one brake pedal, so no matter how good you are, you just can't do that.
    I believe in North America, ESP became optional on the A4 in the 2001 model year. It is pretty rare.
    Apr 22 2007
    Riverbank, Ca
    Its an option. Very rare.
    S4's had it as an option on earlier cars but it was standard on later cars.
    It was a PITA finding an ESP A4 for my wiring harness for the 914. I ended up going S4 with all the do-dads. ESP is very interesting and one of the main reasons for my build :)
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Feb 21 2013
    Warren, MI
    Wow thanks for the info guys, and i did feel that shit kick in this morning purposely trying to get sideways in the rain and it felt like the car was slowing down on its in in fullboost. Now this ESP will effect my winter hooning is their a way to disable such feature? via fuse or relay?
    Jun 30 2008
    Erie, Pennsylvania
    Just push the ESP button. Turns it right off.
    ABS and EDL still remain in effect, though. You can unplug a wheel speed sensor to kill all 3 at once (just pop up the back seat and unplug a rear sensor).
    With just one sensor unplugged, ABS, ESP and EDL are disabled. EBFD (Electronic Brake Force Distribution) still remains in effect, however. This is like a software version of an LSPV (Load Sensing Proportioning Valve). Basically a dynamically adjusted front/rear split. If you want that off as well, you can pull the ABS fuse to shut the whole business down. The side effect there is that the cluster will beep 3 times and flash the BRAKE light due to lack of communication with the ABS module. Unplugging a sensor keeps things quiet while still killing all the "active" nannies. EBFD is barely perceptible.
    I'm not positive, but I think EBFD is only present with ESP. A subset of the ESP feature, methinks.
    Nov 03 2011
    All Over!
    If your car had ESP, there should be a switch to disable it as required.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Was an option when I bought my 2001, but would of had to order it and wait many months. And as mentioned above, there would be a button to disable is.
    Feb 21 2013
    Warren, MI
    ok so what this EPC light? electronic pedal control?
    Apr 03 2014
    17 GTI Sport
    EPC has to do with the cars Electrical system. Usually a very bad sign as they are hard to track down and fix, unless its something easy like a dead battery.
    Feb 21 2013
    Warren, MI
    GOTCHA! thanks for the info and luckily mines off lol im not use to this 01.5 dbw b.s. im use to my summer aeb 97 and 98 daily
    Oct 31 2014
    NH
    Racecars don't need ESP anyways.
    May 03 2009
    East
    Quote Originally Posted by adam044 View Post
    100% Correct! ABS is useful though. Flat spotting your tires sucks ass.
    Oct 31 2014
    NH
    I've never felt my ABS in almost 2 years. Maybe I don't have abs idk.
    Apr 22 2007
    Riverbank, Ca
    Based on my research this is correct. Which is why only ESP cars have the ABS pump.
    Jun 30 2008
    Erie, Pennsylvania
    I have a dislike for the EBFD. The ticking just bothers me. I find myself braking differently just to avoid the stupid ticking. I have wondered if recoding for S4 brakes would change the ticking and give me some more rear bias. I should try this at some point.
