Results 1 to 14 of 14
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    Non S-line to DTM conversion
    So after a recent 'not a fault accident' that led to a hole in my grille and front bumper I'm going to be upgrading my front end.
    I looked into a s-line front end, but becuase the S-Line grille is so damn expensive, the DTM conversion with all the side vents and the use of the replica honeycomb grille works out slightly cheaper.
    I was led to believe that the DTM/25th anniversary bumper is a direct fit to a non-sline a4 but the bumper tabs on the non-s have screws as seen here:
    But the DTM does not have screws as seen here :
    Can I use the screws from my current bumper, or will I need to purchase a new part, if so can some1 hit me with a part #
    In addition, how does the DTM bumper look without the the million dollar lip ? I will be getting the lip but not right off the bat. It is noticeable without it ?
    Can't wait to get this upgrade going, but its a shame to lose my fogs I run my fogs every time im in my car so they will b missed. But will be looking into retro fitting them soon enough. But boy that looks like a bitch of a mod.
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    You can use the ones from your bumper. However when you get the bumper from ECS I believe it comes with mounting tabs.
    Mine came with.
    You'll use the nonsline headlight washers (if you have them) and the grill. I opted to ditch the smaller side grills on the DTM bumper and cut the out for an open scoop. Ps the sidemarkers...just order new ones its so much easier
    I don't have the million dollar lip but still love the look.
    With fog grills
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by DanKing View Post
    Reuse your brackets and for the fogs, follow my DIY: indeed, a biatch
    Without the lip, the bumper definitively looks like something is missing
    Phil
    Aug 14 2014
    California
    Quote Originally Posted by Avant4me View Post
    Mine came with.
    With fog grills
    Did you follow the DIY for your fogs ?
    Also didn't quiet understand want you were saying about the side vents ?
    I can't use the markers from my non s-line bumper ?
    Cars looks great by the way !
    Senior Member Three Rings viperbenz1's Avatar
    Mar 11 2012
    boston ma
    With fog lights
    Aug 14 2014
    California
    Quote Originally Posted by viperbenz1 View Post
    With fog lights
    so damn hot.
    how long did the fog take you to DIY?
    Aug 14 2014
    California
    So after adding things up with my body shop all week, decided to got with the DTM.
    But then ECS tuning seem to had raised there price for the bumper (do note, it was not on sale either) but $200!!! $200 freaking dollars, rideclous.
    Mar 11 2012
    boston ma
    About 4 hours , it's not too bad
    Aug 09 2011
    NOVA
    I followed the DIY
    Things to note. Mounting the fogs to the grill. Fogs need to be high enough to clear the bumper pieces Depending on how you cut the grill to fit the frame this can play a factor. Make sure to use the adhesive in the DIY. other epoxies aren't going to work as well.
    The side vents. I mean the smaller vent/scoops on the outside of the foglight vent/scoops. factory they are blocked off and you buy a grill to go I'm there. I cutout the block off out so more air to intercoolers. Look at my car and they all pass through. Look at viperbenz1's car, he doesn't have the grill in place and you can see the blockoff with mounting spot for the grill.
    Your sidemarkers will fit but just remember they use mounting TAPE. You'll have to peel them off your original bumper and then clean the tape off and out new tape on. It's easier just to use new ones #becauselazy and easy
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    Odd question, but are you able to ask your insurance company for a bumper that didn't originally come with your car? Wouldn't they just get you a direct replacement?!
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Quote Originally Posted by Danaldson View Post
    You receive a check from the insurance company. You can do whatever you want with the money.
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by B-Time View Post
    Ahh okay, never knew how that works
    Aug 14 2014
    California
    So, I might not be going DTM any more :( purely becuase an s-line bumper just cropped up on eBay with grille and fogs for a good deal . mmmm
    May 03 2009
    East
    Most people just pass the check to the body shop. If the repairs exceed the estimate, the body shop with will get supplemental money from the insurance carrier.
