Yeah, make sure the cams and crank are rotated to the correct positions before installing the belt! I'm not trying to be a smart ass, I just think getting your engine into the correct configuration is not trivial. I was still thinking about this after my first post. Here's what I have so far:
1. Remove all spark plugs.
2. Note: Crankshaft rotation direction is clockwise when looking at the front of the engine.
3. Rotate crankshaft to near TDC. (I don't think the TDC mark on the crank pulley matches cylinder 1. I think it applies to cylinder 3 but please research that.) Anyway, rotate it until it is approaching TDC. We want it rotated so none of the pistons are at the top of the stroke because we are about to rotate the camshafts while the crank is stopped.
4. Rotate each camshaft to the correct position to install the cam lock tools. (See notes below.)
5. Finish rotating the crank to TDC. Install crank lock pin.
6. Proceed with timing kit installation.
NOTES:
I don't know if the cam lock can be installed when a cam is rotated 180 degrees out of position. It seems like it could be, which is bad. To avoid this, the only thing I've come up with so far is to position the cams by thinking about the firing order, then following the cam lobes to see which valves are being opened. When the lobes push open the correct valve with respect to the crank at TDC (#3 or whatever), then that cam is correctly timed.
