Looking at b3 and b4 80 quattro sedans. The car will see auto-x and canyons exclusively. Power to weight ratio will be of utmost performance. I will be swapping in a 07k and 01e no matter which car I choose. Probably run an efr6258, only looking for 400hp. The car will be fully gutted and caged with a semi tubed front end most likely, no creature comforts. I'm looking to get as close to 2500 -2600 lbs with driver if possible, sub 2850 lbs is a must. The exterior will be completely stock looking aside from wheels, brakes and being on coils. I will be doing all the work, including any fabrication needed.
My questions are:
Is it worth starting with a b4 instead of a b3? I like the shorter wheelbase and lower starting weight of the b3, but prefer the double wishbone rear suspension of the b4 which is much more planted at speed. Any fixes for the rear being so twitchy on a b3? Obviously locking down the subframe, tubular arms, and higher spring rates help.
Can the b4 be stripped down to be as light as a b3 that's been stripped? I would assume the b4 would still be a bit heavier but are we talking 100-200 lbs or 300-400 lbs? Obviously weight is a big deal, I'm going for as light as possible. I know the b4 isn't that much bigger but from the factory it was 400-500 lbs heavier, part of that from being more luxurious than the b3.
I've also contemplated a 4000cs quattro and b5 a4 for this project but I'm quite partial to the b3/b4 80 look. I'm also not interested in anything outside of audi and awd, just want to make what I love work.
Thanks in advance.
