Results 1 to 4 of 4
    Dec 06 2015
    B13 Nissan Sentra
    Knoxville
    Help With LED Tail Lights on B6 A4 Avant
    Hello all! This is my first thread so whoop whoop. I'd like to say I've had my Avant for 5 days and the Audizine community has helped me with everything from heat shield ideas to the city lights mod.
    I apologize if this answer is clearly posted somewhere but I didn't find anything on multiple searches.
    Sooooooo, I had the bright idea of changing my tail lights and rear signals to LEDs. Looks incredible I might add. The only problem is, and it's not a huge problem as much as just a nuisance. The turn signals are great with no issues thus far. However, when I hold my brakes for more than about 3 seconds, not only will the Warning system say I have a Left Rear Parking Light out, a Right Rear Parking Light(which doesn't even come factory I found out once inside the housing)out, and both Left and Right Rear Lights out, but also my front corner markers with very subtly flash. It's the sort of spark that it makes when you start your car when the system checks all the lights, but just won't stop while the brakes are on. The Warnings and flashes start only after 3+ seconds of braking.
    I'm familiar with the concept that the LEDs draw far less power than traditional lamps, but shouldn't the rear turn signals bug out, as well, if they were as problematic as the tail lights?
    I ordered both sets of bulbs from http://autolumination.com/py24w.htm
    Turn Signals(Super-Power Optical Led Canbus Bulbs $24.99ea)
    Tail Lights(Super-Power 20Led Canbus Bulbs $16.99ea)
    Don't ask why I got cheaper tail lights than signals. I don't even know. But I am wondering if it's simply the poorer quality lights that make the system bug out when the brakes are applied and the higher quality bulbs(like the turn signals) would fix the problem, or if it's just the way things are. Also, ALL front lights are stock as well if that makes a difference. Any and all Help, Comments, Ideas and Jeers are greatly Appreciated!
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    You need led auto bulb resistors. Its not drawing enough current so you will get a light out on the dis.
    https://www.superbrightleds.com/cat/...acement-bulbs/
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    /end thread
    Mar 02 2015
    miami
    how do your turn signals look during the day? mine are bright at night, but are washed out during the day, no error codes tho.
