Just replaced both motor mounts with the 034 street density mounts. I did one side at a time to make sure I wouldn't misalign anything. I tightened the top nut on the motor mount as tight as I could and all the sub frame bolts are tight. I also aligned the motor mount itself as best as I could. Whats weird is the car now drives very well even when driving aggressively. However if I downshift and the revs aren't perfectly matched the car will make a loud thump from the engine bay. very strange to me since I double checked everything and it also drives well except for that. Also the thumping is very prominent coming around a corner and putting the car into 2nd gear without matching the revs, even if it only goes up to 1500 rpm.
