Originally Posted by
nemick
That's great news, thanks. I'm wondering where the ballasts get installed etc on our cars.
If you remove the headlights housings, you will see that there is a cutout for the factory OEM ballast. The Xenon (standard on us-spec B5 S4) headlights have a factory ballast that perfectly bolts in right over there. You can choose to mount them there, but you would then have to determine how to seal up the area from the elements. Another option would be to mount the ballasts behind the housing somewhere in the engine bay.
What type of bulb are you considering going with? I recommend only 4300K or 5000K bulbs for headlights, since they provide the most natural white light (4300K is stock on most cars with factory Xenon, including B5 S4). Anything higher, and it become too blue, and actually REDUCES light output and strains the eyes (ask me how I know). On the other hand, 3000K bulbs are very yellow and are ideal for cutting through inclement weather (i.e. fog lights, rain), but are not good for normal driving.
If you are willing to, I recommend a retrofit as well. There is an adapter bracket available for $30 that allows the H1 mini-bixenon projector to bolt right into B5 facelift housings (seeing that you have a 2001, they will work fine). The ebay projectors are a great budget option, and there is a guy on the forums that will tune them to spec and include a bracket for $30, plus the projectors. While they have very nice output, if you have the money, I highly recommend the Morimoto H1 Projectors from The Retrofit Source. Physically, they are the same projectors, but with a different cutoff shield and calibration, the output is amazing. This is the route I went and I have no regrets. The light output is better than any new car I've driven, and since they are aimed properly, they do not blind others. E-code projectors aren't even a fair comparison.
If you would like to retain the stock projectors, a clear lens is a nice option as well. Replaces the stock fresnel lens, which distorts the light and reduces output. Clear lenses will help sharpen the cutoff. They are $50, although I have a set of B5 A4 projectors with clear lenses on them if you are interested. These will bolt right into your housings, since they are the exact same part, minus the lenses.
Usually installing Xenon HID bulbs in a Halogen housing is a big no-no, but because the facelift halogen headlights actually came with a project (minus HID bulbs and ballast), it is okay to do so. Just make sure they are aimed properly. It will give you better output and prevent you from blinding oncoming traffic.
Here are some resources regarding lighting and the B5 chassis.
The holy bible regarding B5 headlights
http://www.audizine.com/forum/showth...and-HID-Thread
A DIY I wrote, on how to retrofit your headlights withe H1 bi-xenon projectors
http://www.audizine.com/forum/showth...ur-Headlights!
Well, this post ended up being A LOT longer than I intended it to be. If you have any questions regarding the headlights, please don't hesitate to ask or PM me
